Just for fun on a rainy day
Discussion in 'Stove Forum' started by Twoberth, Feb 19, 2020.
  1. Twoberth
    England
    While Storm Dennis was rattling through, I decided to make a small stove to match a pan I had found at a car boot. Here it is, it's a 2 inch high petrol lipstick roarer, with wick and gauze. It fills (about 10 ccs) from the bottom.
    The camera wouldn't focus on the water because of the steam, but it is boiling!
  2. presscall
    @Twoberth
    That’s grand. How do you fill it? I was thinking the lipstick’s threaded but I can’t see spanner (wrench) flats and it looks like it’s brazed at the joint - filler cap in the base like an older pattern Radius 42.
    Head back to the car boot with it and if a stove collector comes along see them freak out.
  3. Twoberth
    England
    Spot on with your observations and interpretation John!
    Yes, the stainless lipstick, it's cap and copper sleeve are all brazed together and then brazed onto the tank. Wick assembly is pushed up inside the lipstick using long tweezers through the recessed filler hole underneath.
  4. presscall
    @Twoberth
    Stick a right-angled coil burner on that, lay it on its side and you’ve a mini-Borde - or (hushed tones) a bomb!
    Looking forward too to the paraffin version with the tiniest of pumps.
    The Lamb paraffin stove holds the record for smallest at present, I reckon.
  5. Twoberth
    England
  6. Simes
    Simes Subscriber
    @Twoberth, according to the weather forecast you have quite a few 'rainy days' ahead to ponder Johns suggestion. :)
  7. hikerduane
    Pretty neat, how long will that wick last though?
  8. Twoberth
    England
    Unknown, but it’s cotton string.
    Same string I use to make eleventy one rags.
