kerosene alternative
Discussion in 'Stove Forum' started by Ahmed Hosny, Dec 8, 2021.
  1. Ahmed Hosny Egypt
    Egypt
    Hello
    i need an alternative for Kerosene for my stove
    any suggestion?
  2. Scrambler
    Australia
    Ahmed, is this for Egypt? And particularly, what stove?
    Do you not have kerosene? The Bushwalking NSW global list has "al-kayruseen, zayt al-barafeen, zayt al-kaaz" as equivalents.
    International fuel names for backpacking stoves
    A quick google suggests Egypt is a significant producer of kerosene.
    Depending on the stove, other non-volatile mineral oils might be suitable.
  3. Tony Press
    @Ahmed Hosny
    Welcome.
    Jet-A1 aircraft (jet) fuel is kerosene. I use it in my stoves and lamps.
    Best regards
  4. A A C
    A A C Norway SotM Winner Subscriber
    Agder Norway
    @Ahmed Hosny
    Hello Ahmed. I run all my kerosene stoves on charcoal lighting fluid (for barbeques) . Its cheap and available in supermarkets .
  5. Ahmed Hosny Egypt
    Egypt
    @Scrambler
    yes Egypt, Primus stove
    Right Egypt is a significant producer of kerosene but for B2B purpose only, so i can't buy kerosene as a consumer
  6. Ahmed Hosny Egypt
    Egypt
  7. Ahmed Hosny Egypt
    Egypt
    @ACC
    unfortunately, not available in Egypt
  8. A A C
    Agder Norway
  9. Fettler United States
    Ioway
    No charcoal grill lighter fluid available in Egypt? That's a shame.
    Time to start looking at what are called CAS numbers. There are possibly some products in your country available for automotive parts shops or possibly woodworking, solvent tank parts cleaners i.e. "Odorless mineral spirits" and the like. You might be able to find something that is almost identical to kerosene in every respect, except by name.
  10. Ahmed Hosny Egypt
    Egypt
    @Fettler i found Turpentine, but i do not know it considered as an alt for Kerosene or not
    but i am still searching according to your advises
    thank you all :)
  11. Tony Press
    Many products sold as turpentine, and much diesel, will not be a proper equivalent of kerosene. They might work, but are likely to produce carbon and other by-products that will clog jets and burners.
    Jet fuel is made to a global standard. That is where I would go first.
    Best regards
    @Ahmed Hosny
  12. A A C
    Agder Norway
    This is what is in grill charcoal lighting fluid:
    Hydrocarbons, C10-C13,
    What do people burn i lamps in Egypt ?
  13. snwcmpr
    FYI
    Jet A does not have the deicing agent Jet A1 has.
    So, if you can get that, all good.
  14. Felipe
    Lima Peru -Sudamerica
    Amigo Ahmed,,, use Turbo Jet A-1...llama limpia azul...perfecta
