Hello everybody, I have repared an old Primus nr 5 silent burner. The fuel that I purchase in Belgium is called "liquid for lamp" On the bottle it's specified "contain isopropylic alcool (200-661-7) and methylethylcetone (201-159-0) Is it the right fuel for the burner, because in Belgium I cant find a product called "parafine" or "kerosene" ??? because it's very difficult to ignite the burner !! Thanks a lot
Bonjour @MARC PRESCHIA The fuel you need for the Primus N°5 and similar stoves is pétrole/petroleum. Also useable is BBQ lighter fuel (pour allumer le bbq). In most Do-it-yourself stores like Hubo, Gamma, Brico etc. le pétrole is sold in 1liter plastic bottles, or 20liter jars as fuel for Zibro Kamin and similar small "portable" heaters. Sometimes one can find le pétrole in bulk (bring your own can) at places selling heating oil (mazoute), black coal (charbone) and/or bottled gas. Those are the cheapest option, costing less than 1 euro/liter. When lighting the burner, one must first pre-heat with alcohol in the pre-heat cup under the burner. I get alcohol in 1liter bottles (bio-ethanol) at Action for roughly 1,5 euro/liter. Hope this helps, if any more questions, just ask! Bien à vous, et bienvenu à bord, Wim
Hi Wim, thanks for your info. In the meantime I made a test with what we call in french " petrole lampant" or "tosaine" used for cheap petrol heather and it's perfect. Your answer confirm my test Hartelijk bedankt Wim
Petrole lampant is similar to the "kerosene" or "paraffin"(different names in different countries) we use in pressure stoves, pressure lanterns and most burners with adjustable wick.
