Lipstick burner question.
Discussion in 'Stove Forum' started by Deleted Account 250821, Aug 14, 2021.
  1. Deleted Account 250821 Guest
    To promote excelent contact between burner bell and lipstick tube can the be threaded?
  2. ArchMc
    ArchMc SotM Winner Subscriber
    Mojave Desert, California
    I don’t see why not. After being heated to burner temperature and then cooling off, it might be difficult to take apart.
    ….Arch
  3. hikerduane
    Extra process at the factory, extra material needed on parts. ?
  4. Murph
    Milwaukee WI, USA
    NOT a good idea.
    They fit so tightly that you can have problem taking them apart without threads, threads can only make things worse.
    Murph
  5. Rangie
    Rangie Subscriber
    Or you could make them in steel like the Army No.2 Mk2. Not strictly a lipstick but as near as dammit, and the buggers always come apart :D
    Alec.
  6. presscall
    Certainly the threads on the vapouriser couldn’t be cut in the thin steel of a conventional lipstick vapouriser.
    Alec’s referring to this arrangement - two of each component here because they’re from my No.3 stove (double burner No.2).
    9B26492E-F166-42C5-84E2-34104837AAFE.jpeg 7B5CBDB7-37BD-4003-90DC-462E670538ED.jpeg CA5FFC0B-5CBF-4BDA-B6F7-5A96BD456FF5.jpeg
    A crucial point here is that the mass of metal in a No.2/3 burner requires the volatility of gasoline to sustain vapourisation. Double priming, or use of a blowtorch to prime, can get kerosene to vapourise, but only for a short while.
    A Primus 107’s burner dodges the collapsible stoves’ (‘96’, ‘100’) conundrum by having the burner bell permanently attached to the vapouriser component.
  7. Deleted Account 250821 Guest
    Thanks Presscall,
    Those photos of the barrel nipples with the jet in the end is pretty much what i had in mind.
    I have a 316l 1/8 bsp nipple and a brass end cap.
    I may have to make the barrel from brass-actually more fun that way.
    I also used your tutorial on hypodermic needles.
    I can get .5mm lpg screw in jets by the bucket load for $4 a piece.
    I ream it with a .5mm drill and press the needle in and sand with 400grit w&d paper.
  8. presscall
    Better thermal conductivity too.
