Lipstick repair
Discussion in 'Fettling Forum' started by Twoberth, Oct 25, 2020.
  1. Twoberth
    England
    This is how I repaired an old Monitor lipstick, on which the top was so badly damaged that it was not repairable and needed to be sliced off.
    The Lockdown Fairy had brought me a jeweler's doming punch set that was ideal for making the cap.
    First I annealed the brass rectangle and then formed it using the largest punch that would fit inside the lipstick (11mm) and a matching cup for the 0.8mm thick brass. Then I re-annealed the cap and cut off the excess, and then restamped.
    After sanding flat the mating surfaces the cap was silver brazed onto the lipstick tube.
    Then sanded smooth
    The very top was tapped flat and then centre punched to guide the small drill (thanks @igh371 ).
    Then the gauze was replaced and the lipstick fitted to the tank
    Then lit. After an intermediate peen to get the flame correct the stove runs like new.
    As a bonus, after an extended burn the polish marks have tarnished and darkened and it is difficult to tell that the lipstick has been repaired.
  2. Ian
    Ian Subscriber
    West Yorkshire
    Beautiful work.
  3. Optimust
    Hi Twoberth, a great repair & presentation, love the jewelers domeing set & the scroll
    drill. Good Blue flame equals Good job done. :clap:Best to you, Optimust.
  4. Marc
    Marc Subscriber
    Oregon, USA
    Fantastic work, well done.
  5. igh371
    That really is a superb piece of work,
    Ian:thumbup:
  6. Haggis
    Haggis Subscriber
    Northeastern Minnesota
    Nicely done...
  7. Twoberth
    England
    Thanks everyone.
    Things don’t always go to plan, but fettling is fun.
  8. hikerduane
    Nice. That domeing tool would be nicer than a sanded down stove bolt when I peen my burners.
  9. kerophile
    Impressive fettling work.
  10. Twoberth
    England
    Thanks Duane and George.
  11. hikerduane
    I sliced into the top area on one I had as it was crushed some. When I tried to force the area, I cut into the side, so got lucky when I was able to silbraze it then grind off the excess.
  12. JP2
    JP2 Subscriber
    Canada
    Nice work, Bravo
