Lux 9 pre 1915
Discussion in 'Lux' started by kaw550red, Dec 22, 2009.
  1. kaw550red
    kaw550red RIP
    Optimus bought Lux in 1914 so it is safe to say that it was made before 1915.
    Whilst Optimus do not appear to have made any Lux models they did use the Lux dimpled spirit cup and the Lux shaped legs on at least the 00s and the dimpled spirit cup on other models.
    Optimus stoves with these features cannot have been made before 1914 unless the spirit cup or legs are later replacements.
    The dimple can just be seen at the left of the spirit cup.
    The leg identification information is HERE
    Regards Bryan
  2. jenspetter 123
    Hi Bryan
    Lux made great stoves. :lol: I have got a Lux 13 if I remember correct. A little bit bigger than your nr 9.
    Regards
    Jens
  3. hikin_jim
    Bryan,
    Are you familiar with the purpose of the dimple in the spirit cup? I'm assuming that one would position the tube on one's spirit dispenser into the dimple so as to facilitate dispensing the meths, but I wonder if there is any other reason.
    HJ
  4. kaw550red
    kaw550red RIP
    Hi Jim
    The idea was very simple. The dimple still contained spirit when the rest of the cup had burned out so there was a flame to light the burner when you pumped the stove up. The problem that I noticed was that by the time the spirit had burned to the bottom of the cup the metal was really hot and the spirit was boiling so you had to be quick to take advantage of the residual flame. I presume that this was a general problem as the idea was dropped I think at some time in the 1930s
    Regards Bryan
  5. stejar
    Sweden
    Hi Bryan!
    A real beauty you have there. It’s always a pleasure to see one of those old brands.
    Is that a Lux filler cap? I was not aware of Lux using that model. I have seen it on Optimus and Prisma stoves, but not on Lux. I could be that the use of those filler caps on Optimus is another consequence of Optimus taking over the stove part of the Lux Company.
    Regards Stefan
  6. kaw550red
    kaw550red RIP
    Hi Stefan & Jim
    The tank lid was a Lux tank lid
    Jim Providing that the dimpled spirit cup is original your stove could have been made before 1914 and is unlikely to have been made later than the 1930s. Unfortunately whilst I think it finished in the 1930s I have no idea when it was dropped
    Is the address on the tank Stockholm or Uplands Vasby? Stockholm was the earlier address and Upplands Vasby came in sometime near the middle 1930s.
    What is written on the top of the burner?
    The markings on the tank are a much more reliable indication of age as owners cannot change them.
    00s were never fitted with aluminium legs so you probably have a set from an RM, Thermidor or Veritas stove. They were perfectly safe. In fact my special stoves are usually fitted with aluminium legs to reduce their weight. It was an idea created in the UK after WW2 because steel was in very short supply whereas there was a glut of aluminium because it was no longer needed for war planes
    {admin - moved to new thread}
    Regards Bryan
  7. Spiritburner
    Quite possibly a consequence - Lux did that style, a flat version & a winged version that I am aware off. The first 2 I have, the winged I have seen in the catalogue (on site).
    It's good to clarify that Optimus did not take over AB Lux.
    From Optimus article;
  8. Riddarn
    Hi guys..
    I have an idea about the "dimpled cup"..
    Isn´t it for the pilotlight, so that it will take the last remains of the spirit,
    so that the lighting will be nice, without disturbing underburning"?
    Best regards, and a very merry Christmas..
    I am just in the process of making a Christmas ham,
    a.k.a "Julskinka"
    Uffe
  9. kerophile
