M-1942 question
Discussion in 'Fettling Forum' started by yonadav, Sep 8, 2018.
  1. yonadav
    Israel
    I am trying to refurbish an old M-1942. (Don't know which make.)
    It is missing a part shown in the diagrams as "packing", that sits between the valve assembly and the generator.
    Can somebody tell me how to make one? What material and what dimensions?
    Thanks,
    Yonadav
  2. cottage hill bill
    cottage hill bill Subscriber
    Contact Mike at He has repair kits for the M1942 and M1950 which will have all the parts you need for a complete overhaul. Good prices and excellent service.
  3. yonadav
    Israel
    Mike who?
  4. cottage hill bill
  5. yonadav
    Israel
    Thanks, Bill.
    Anybody with details of the missing packing, so I can make one myself?
  6. Duck United States
    Just east of LaLa land
  7. presscall
    Good to hear from you @yonadav
    You’re referring to the graphite packing in the control valve I guess.
    That on mine was intact, but I’d have no hesitation in using the graphite sheet that Terry (Trojandog) sells. A strip can be rolled around the spindle and prodded in place with the tip of a thin screwdriver. The strip will no doubt break in rolling it but that doesn’t matter. A succession of inserted strip pieces, compressed each time by screwing down the packing nut, will gradually build up the depth of graphite required.
  8. richmay
    I believe @yonadav means the packing piece that i have highlighted on @presscall photo
    Richard
  9. pau-i-amor
    pau-i-amor Subscriber
    17190 Salt, Catalunya
  10. snwcmpr
    I am with CHB, one can pack graphite sheet or rope into the area and it will conform to the shape. Add more as needed.
    I use @Trojandog graphite sheets.
  11. yonadav
    Israel
    Thanks for the warm welcomes, friends.
    I am referring to the disk shaped thing that Richard pointed in the photo. It is supposed to hold the generator in place on top of the valve body. Without it the generator is wobbly after you tighten the nut that has the primer cup on it.
    I don't think graphite sheet or rope can do the job.
    Yonadav
  12. yonadav
    Israel
    BTW, I cleaned enough soot off the stove and discovered that the one I have is made by Prentiss-Weber.
  13. snwcmpr
    That does look like it is a machined piece of metal.
    Someone with one might be able to give you dimensions.
  14. cottage hill bill
    I'd suggest posting a Want to Buy (WTB) thread over on the Coleman Collector Forum (CCF). That piece isn't part of the normal repair kit. There's a good chance that someone over on CCF will have one from stove that's been parted out that they will sell or give you. Use the picture that rickmay added the arrow to when you're asking on CCF.
  15. SKLColorado
    Colorado Springs, Colorado
    Yep, that disk is made of steel and graphite won't work, unfortunately. Let me know if you are still in need of one to either use as an example to machine your own or for use. Contact me at my blog.
