M1950 Coleman1951
Discussion in 'Military' started by anfeng, Sep 6, 2017.
  1. anfeng
    anfeng SotM Winner Subscriber
    When I get it from an American seller on ebay, these things come together and it looks like a good combination.
    Everything is in this m1961 canvas bag
    The support fits perfectly with the frying pan
    There is also a M1956 instruction in the bag
    M1942 and M1950
    After replacing all the rubber parts, it was reignited
  2. Tony Press
    @anfeng
    It is indeed a very good combination.
  3. shagratork
    An excellent presentation.
  4. presscall
    Very well presented @anfeng, thank you.
    I wonder what 'knickknacks' an inexperienced soldier tended to load himself down with? Bric-a-brac to make tent life more homely?
  5. ROBBO55
    G'day @anfeng , looks like a complete Mountain Cook Set to me. Congratulations :clap:
  6. Levi Porter
    Nice purchase, I also was watching that item. Glad to see you appreciate the set.
  7. anfeng
    The army had to use the car gasoline at the time of the U.S. army's m1950, and basically you had to burn what Willis was burning, and it was easy to get a carbon on the stove.
    M1950, which was produced in 1951 and served in 1987 for 37 years, has not changed its design from the beginning to the last.
    In the case of carbon blockage, the American solution is convenient and fast replacement of easy block parts.
    Remove the pan support assembly.
    Remove the bell burner bowl with a wrench.
    Remove the bolts under the preheating tray.
    This is the part that can produce carbon, the nozzle, the riser, the copper coil.
    If you are pressed for time, you can change into a spare burner tube assembly, which you can find in the pump rod. The whole replacement process takes only a few minutes.
    In your spare time you can clean up the charcoal in the replacement parts. A pin is a good tool.
    In addition, the pump check valve is also easy to maintain.
  8. anfeng
    I try to make up for my lack of English by using pictures. I hope I didn't cause you too much trouble. Thanks for all the friends who have been paying attention to my topic.
  9. anfeng
    If you shut off the valve and still have the gas leaking from the nozzle, try replacing the fluoro rubber gasket for the unit.
  10. presscall
    I'm English and always aim to do the same and your dismantling and photos are excellent.
    A very, very good post.
  11. Tony Press
    Thank you, @anfeng, for the tutorial on "field maintenance" of the M1950.
  12. kerophile
  13. anfeng
    Thank you Kerophile! These two British soldiers may have been fed up with Austin Champ and traded with American soldiers, ha ha!
  14. kerophile
  15. anfeng
    @kerophile
    Learn some knowledge about Austin Champ, thank you!
  16. Levi Porter
    Good summary on the disassembly/assembly. Images always help regardless of language.
  17. Billofthenorth
    Billofthenorth Subscriber
    Michigan, USA
    This is an older thread but I just happened across it. I had thought the jet and generator were one piece and never realized the jet could be unscrewed from the generator. So I'll add my thanks for the information....now to properly clean about 5 generators and jets in the spares bin.
