`Magnetic tank cleaning
Discussion in 'Fettling Forum' started by fyldefox, Dec 3, 2008.
  1. fyldefox
    fyldefox R.I.P.
    This is another technique which might be of use in cleaning the inside of tanks.
  2. North61
    Whitehorse, Yukon
    Now why didn't I think of that? Great idea. Thanks.
  3. sefaudi
    So, the matter is to get a Neodymium Magnet.
    Really are they so strong?
  4. DAVE GIBSON
    DAVE GIBSON Subscriber
    very--very clever and well thought out.putting the magnet in the polishing cloth and the steel wool follow up are a step beyond what i would have done..those magnets can be found on the web.
    i have a plain magnet,but very strong,i'll have to try it out with that--
  5. parramethtrol
    parramethtrol Subscriber
    8) the best idea's are usually the simplest :clap:
    i read that you can clean the inside of engine blocks by electrolysis by filling the cavity with soda solution and then feeding a wire inside some plastic tubing that has small holes in down through the opening then connecting the wire and engine block to the charger in the normal way,i haven't tried it but reckon it would work on steel tanks
    that and the polishing method in the link could be very effective,now i need an old steel tank to try it on ;)
  6. BernieDawg Banned
    This is an absolutely superb idea! :clap:
    For years I cleaned the algae off the glass on my aquariums (no longer have them) using a pair of magnets that were faced with a Scotchbrite-like material. I never put that idea together with cleaning fonts/tanks. :doh: I've been using sand, BB's and a slosh of kero to do the job. And, boy, do I get worn out shaking that tank around. This adds another tool to the kit.
    Thanks Fyldefox for bringing that idea over from BBL! Most excellent! :thumbup: :thumbup:
    Gary
  7. 111T
    111T Subscriber
    Olean New York USA Earth
    Yeah they're very, very strong. That's a pretty good idea! :idea: :clap: :clap:
  8. fyldefox
    fyldefox R.I.P.
    Thinking about it, it should work better with non-magnetic rather than steel tanks :-k
  9. Dutchmike
    Netherlands
    Hello All, on steel tanks they will not work for the obvious reason of clinging too tight to move.
    But why bother? Anything to be (re)moved from inside the tank, be it sediment and / or oxidation, can be achieved simply by pouring in some nuts and bolts (the small size, that is, and no fluids) then shake and stirr. Scraping with just a washer might be appealing to those who can not bring themselves to an upper-body workout, but the former method is by far the speediest, as we can observe that action = reaction!
    Mike
  10. sefaudi
    Hey Keith, you are 100% correct as with steel tanks, the magnet will loose most of its power onto the tank itself.
