Making pump leather cups. Two attempts
Discussion in 'Fettling Forum' started by pau-i-amor, May 30, 2020.
  1. pau-i-amor
    pau-i-amor Subscriber
    17190 Salt, Catalunya
    This is not a "Pro" job neither a tutorial, only two simple attempts cause I couldn't find these leathers cups size. I asked for a piece of leather to local shoemaker. I realize is to much soft... but good enought. I soak a leahter cutout in water for 20 minutes before using.
    First attempt:
    For an old brass hand pump I need a 22mm diameter cup. First FOCUS stoves had not a built-in pump.
    I drilled a hole in a wooden board. First with a 20mm Diamter drill. Then with a 22mm D drill only HALF DEEP. With a sandpaper I got a tappered bore. I cut a 20mm D wooden stick and sand a conic shape in one end. Both was varnished.
    I pressed the leather with a clamp for one night. Voilà!
    I cut the extra leather behind the board with a cuter. It isn't a good idea...
    I made a hole.
    I assembled the new leather cup. Leather cup spend one night soak in oil.
    Second attemp:
    A 34mm diameter leahter cup for a fuel tank pump. I drilled a 32mm Diameter hole and tappered a little with a sandpaper.
    You can see the conic end of the stick.
    Wet leather is so soft you can shape it with your fingers!
    Soaked leather is darker than dry...
    In this case I cut the waste with a scissors.
    These are the pump parts. You can see the old cracked cup.
    I assembled the new cup.
    One night soak in oil.
    The extra oil drops for a long time.
    This is the result
    I reach 2kg/cm2. It's good enough for me!!!
  2. Ed Winskill
    Well done.
  3. Tony Press
    Excellent!
  4. Majicwrench
    Majicwrench Subscriber
    I form the cup right in whatever pump tube you will be using it in.
    Good on you for getting it done. Always fun to learn something new.
  5. Harder D. Soerensen
    Denmark
    Well done - your post here can certain work as a tutorial!
  6. hikerduane
    Nice thinking. I had to make a cup for my Governor.
  7. snwcmpr
    snwcmpr Subscriber
    Well done sir.
    :clap:
  8. ROBBO55
    The pumps worked so the leathers look good to me. :thumbup: :)
  9. Metropolitantrout
    Santa Cruz, CA
    Looks factory :thumbup:. Well presented! Jerry
  10. Sternenlicht
    Sternenlicht Subscriber
    Hürtgenwald
    Wow, so simple! Great idea to make the moulds from wood!
    Ciao, Bastian
  11. Tantra
    Tantra Subscriber
    China
    Good job
