Hey. Got this MOHA No1 stove that I am trying to fettle. Under the tank there is Germany. It could be fun if there is someone who could tell a little about the stove. There is no valve at the bottom of the pump tube, but only a 3.5 mm hole. This part with an NRV sat soldered inside the tank, and stuck out at the filler cap, Have never seen it before on a stove. There may be someone who thought it should be sitting there. Tom
Just a few pictures Then it manages to get the MOHA up and running after removing and soldering the pump pipe. The NRV which is soldered to the end of the pump pipe had also come loose. Tom
