Monitor 17B replacement burner
Discussion in 'Stove Forum' started by Twoberth, May 27, 2020.
  1. Twoberth
    England
    I have posted how I make lipsticks, flat pack burner bells (here) and flame plates before. However this time when I made the set I decided to make the flame plate from steel with twisted supports. The result was good, and I now have another working Monitor 17B.
    2020-05-27 001 019.JPG 2020-05-27 001 018.JPG 2020-05-27 001 017.JPG 2020-05-27 001 007.JPG 2020-05-27 001 005.JPG 2020-05-27 001 011.JPG 2020-05-27 001 012.JPG 2020-05-27 001 004.JPG 2020-05-27 001 003.JPG 2020-05-27 001 001.JPG
    The lipstick stem is made from thick tube and so the thermal feedback downwards to the tank is very good. The lipstick stays very hot and a gauze inside is not really needed, but I put one in anyway.
    The jet hole is 0.23mm as best I can measure, and I am pretty sure the yellow tips on the flame will disappear when all the grease and crud has burned off.
