Monitor High Speed Picnic
Discussion in 'Monitor' started by Twoberth, Nov 14, 2019.
  1. Twoberth
    England
    This is an early Monitor HSP as it has the small spirit cup, but possibly not the earliest version as it is in a 'one rivet' cabinet (see here).
    The cabinet is very clean with little sign of wear and tear.
    The burner is, I think, the earliest version with a small captive spirit cup. It is certainly pre-1950 patent as it had no burner slits (until I got at it) and a separate cast iron burner plate.
    Because the burner bell tends to stick on the lipstick, I cut two slots (not very straight) in the collar as in the later burners.
    The tank is the earliest version with male pump collar, knurled pump knob
    and PARAFFIN ONLY stamped in a box on the side
    Since it is designed to be used in the cabinet, the feet are nothing more than brass 'buns' soldered to the base
    The stove is very well made with heavy tank and burner fittings, and a threaded lipstick for the travelling cap (aka the snuffer).
    The snuffer is 'home made', with a larger hole to fit securely under the cabinet clip (I have no idea why the original snuffer hole was so small)
    After fitting a new filler lid washer, peening the lipstick and fitting a new brass gauze the stove worked straight away, although it needed a double prime to get the heavy burner plate and burner up to temperature. I now know why the later burners had a larger spirit cup!
    The spanner fits under the tank when travelling,
    and the box, box logo, cabinet decal and instructions are all copies of the originals - thanks to photos posted on this site
  2. ROBBO55
    Congratulations @Twoberth , it's in great condition. :thumbup:
    Nice touch making a new box and label to protect the stove.
