Monitor stove.
Discussion in 'Fettling Forum' started by manfrommanchester, Nov 13, 2019.
  1. manfrommanchester
    Got one of the above . Not used it for about 9 months. However when I did seems the NRV is seized up. ( When I pump it there is only resistance. ) How do I go about freeing it. Hopefully without resorting to having to take it out.
  2. presscall
    @manfrommanchester
    Prop the stove tank with the pump tube vertical, pump removed, and spray/pour releasing fluid/oil in the pump tube to give the NRV innards a good soak - it penetrates through the air inlet hole in the NRV head. Leave it there as long as patience allows.
    No guarantee it’ll work but a good chance.
  3. Tony Press
    ...and after that, half fill the pump tube with paraffin and force it through the NRV with the pump.
  4. kerophile
  5. Twoberth
    England
    I usually do what @presscall suggests, and after a few minutes I poke a thin, flat-ended wire (e.g. a length of bicycle wheel spoke) through the air hole and lightly press down. More often than not this opens the NRV, and the releasing oil flows through the hole and lubricates the spring and case bore walls.
    If it doesn't release under slight pressure I leave if for a while longer and then try again.
  6. manfrommanchester
    Worked. Cheers guys!!!!!
  7. Simes
    Simes Subscriber
    Indon't think I could fettle without an old bike spoke. :thumbup:
  8. Marc
    Marc Subscriber
    Oregon, USA
    I use TIG welding rod for the same purpose. :thumbup:
