My first Svea 123
Discussion in 'Svea No: 123 & 123R' started by firedog, Jul 13, 2021.
  1. firedog United States
    down south
    I turned 60 in May of this year. My fascination with stoves started in my early teens when backpacking with my father. Until I ran across this stove and forum--I thought I was the only person with this interest. This one was a Ebay find and I probably paid a bit too much but oh well. It is due here on Thursday and hope is in a good of condition as the pictures, description and conversations I had with seller portrayed. I've never owned one these and it felt right just biting the bullet and starting out with one in descent condition (fingers crossed). Look forward to any conversation--good or bad.
    Question: I'm thinking this a "R" version?
  2. IvanN
    N.E. Oregon
    You are in the right place. A lot of us here have said that. I’m on my phone’s screen, but it’s a 123r.
    If the valve stem is horizontal it’s a r, if it slants downward it’s pre r.
    Lots of good info and helpful people here.
    Most importantly, welcome to the forum!
    Ivan
  3. firedog United States
    down south
    Thanks, I'm sure I will have some more questions pertaining to this one
  4. Tony Press
    Welcome, @firedog.
    A Svea 123R is a good stove, have fun with it.
  5. Fettler United States
    Ioway
    You've got the bug! (I can tell)
    I wouldn't even consider going on a hike without my trusty Svea. I've tried a whole passle of different stoves.
  6. firedog United States
    down south
    I carried a MSR Whisperlite for many years. When I started venturing further from home, the canister stove proved much easier to please the TSA. One whiff of fuel and they freak out. Not a issue on the way out but much more a pain on the way back. Just knocking around here I use something different most every time. I've always been curious about the this Svea and ran across this one and the rest...
  7. Yun124
    Yun124 Subscriber
    Gangnam, Seoul in Korea
    Nice condition, looks almost new one!
    Just to check the Safety return valve which is integrated on the fuel tank's Lid cap in advance to fire this up.
  8. firedog United States
    down south
    Seller said that owner only used a few times. Please, how to check above described valve. And, are there any gaskets that I might need to replace and source for same. Thanks in advance.
    s-l1600 (3).jpg s-l1600 (1).jpg s-l1600 (4).jpg s-l1600 (8).jpg s-l1600 (5).jpg s-l1600 (6).jpg s-l1600 (7).jpg
  9. Tony Press
    If it’s reasonably new, and little used, you might not need to do much at all.
    First, familiarise yourself with the instructions.
    Second, to test for leaking washers, with the control spindle in the fully off position, cool your stove down in the refrigerator or icy water. Then submerge it in warm water and see if air escapes from the filler cap, the safety valve (on top of the filler cap), or the control spindle. If so, get back to us. If not:
    Third, prime the stove (I use methylated spirits rather than Coleman fuel for priming as it doesn’t soot the stove up) and light as per instructions.
  10. firedog United States
    down south
    Just received and unpackaged same. It is truly like new. I'm totally satisfied. Will test it tomorrow some time.
  11. Yun124
    Yun124 Subscriber
    After Preheat the tank and viporizer under the burner bell in order to make pressure in the tank, then you can check the leakage from the SRV, the tank lid.
    Refer the photo you can see, tiny fire on the valve hole, which means the Gasket in the lid is not on proper condition.
  12. firedog United States
    down south
    This gasket appears to be in "like new" condition. I will test as Tony described above. I would like to have spare parts to include this gasket. Are these parts readily available? Where?
    Thanks in advance
  13. firedog United States
    down south
    Of course Amazon has one form Optimus. Is this compatible with this era of stove?
