Mystery Meths stove flames!
Discussion in 'Mystery Stoves' started by kenpyro, Mar 15, 2012.
  1. kenpyro
    I had to do a bit of thinking as to how to get this one going as there is a part missing that allows the cone shaped wick to create a seal and dip into the alcohol.
    Thank goodness for foil! :D/ Wrapped it around the wick and made just enough seal to get the meths to do it's thing! Addicting or what????
  2. RonPH
    I have something similar. Between the cone shaped burner and the tank it has a cloth which is wrapped around all the way down and is about 2-3 mm exposed. The cloth is lighted and preheats the cone eventually you get flames coming out of the tip of the burner.
    Ron
  3. kenpyro
    Thanks! Would you happen to have any photos to share so I can replicate?
    KenPy
