Mystery stove, Burmos or Primus ?
Discussion in 'Stove Forum' started by Bigbear, Jul 11, 2020.
  1. Bigbear
    Bigbear United Kingdom Subscriber
    Bradford UK
    B565A2E7-CFB9-4B9A-934D-83B725BF9D8C.jpeg 11612254-98A2-4E4E-869C-C996B3E8864F.jpeg
    Bought this stove for a fiver the other day, thought it was a primus as the filler cap says that on both sides, but the pressure release key says British and Burmos on either side.
    No engraving like the Primus 5 in the pic on the right.
    What is it likely to be ? A Burmos with a spare filer cap from Primus ?
    Any idea what model ?
    Thanks as ever.
  2. kerophile
    Hi @Bigbear Both filler cap and air-screws are detachable from the mystery stove, so not a reliable indication of parentage.
    Some Burmos stoves had a concentric fold on the tank base, like this example:
    What does you tank base look like?
    The shape of the top of the legs/ pan-supports on your stove are also quite distinctive, with a very open bend. Again some 2-pint Burmos stoves had this type of bend, whereas Primus never did until after assimilated into the Primus Trading Co. post 1962.
  3. Bigbear
    Bradford UK
    Yes, its got that fold so it must be a Burmos. Thanks so much.
    Any thoughts as to the model ? will primus parts be suitable for a refurb ?
  4. kerophile
    Hi, probably a Burmos 5S from late 1940s/early 1950s.
    Fixed leg, silent burner, around 2 pint capacity kerosene stove:
    Very similar to these three examples:
    Burmos
    Burmos Fixed 3 Legger
    Burmos No 5 ?
    And yes, your Burmos should accept Primus parts.
  5. presscall
    Just as well it was a Burmos, it went straight in the Stove Reference Gallery as one. I’m not a stickler for forum protocol @Bigbear but your query would have been better placed in the Stove Forum.
    This bit’s where someone can find examples of stoves already identified to refer to - close up shots, details.
    Looks like one of mine. Photo of base, distinguishing feature, a reference.
  6. kerophile
    Hi @presscall I do apologise for not referencing your bottom.
    Please forgive me,
    George.
  7. Bigbear
    Bradford UK
    Sorry, new to the forum, no intention to offend, will note for the future.
  8. Bigbear
    Bradford UK
    So helpful, you must spend too much time doing this ( as if that were possible, already thinking about buying more !).
    Regards
    Nick
  9. presscall
    @Bigbear
    Hey Nick, absolutely no offence. I feel a p*llock now for mentioning it. Just wanted to assist in helping you into things.
    George, you devil!
  10. Bigbear
    Bradford UK
    OK got new burners but cannot prick the jet, is it worth trying to soak whatever is in there or do I need to replace the nipple ?
    Many thanks.
  11. Bigbear
    Bradford UK
    PS got an odd look from my wife when I said that I had problems nipple pricking.....
  12. Spiritburner
    Moved so all's good! :thumbup:
  13. ROBBO55
    @Bigbear
    If the jet is blocked soaking the nipple in paint thinners or acetone may help.
    If that fails I heat the nipple to dull red and drop it into cold water. Repeat if necessary.
    Usually works for me.
  14. Bigbear
    Bradford UK
    Thanks, will try that, apologies for not starting a new thread in the right place.
  15. Bigbear
    Bradford UK
    Well, IT WORKS ! My first successful fettle, thanks tomall the help Ive had.
    Waht a great feeling when it fired up first go, but I guess you all know that feeling too, or you wouldn’t be on here !
    Thanks again folks.
