N. American adaptor needed
Discussion in 'Stove Forum' started by Angela Dawson, Oct 28, 2020.
  1. Angela Dawson Canada
    Vancouver,, BC
    I have the Primus Model #2399 which although a European model, and old is in good condition. It used to be possible to buy gas for it but now I have got it out of storage I find it needs an adaptor to fit even a small N. American gas tank. Could anyone tell me where to find one. I've tried local stores in Vancouver, BC but no luck so far.
    Many thanks.
  2. aomb30
  3. Lennart F Sweden
    Vänersborg, Sweden
    The adapters shown at Primus site are for the new system that adapt the tank side connection - the older stoves has a threaded hose connector to the combined tank connector/regulator valve where you just shift the connector/valve unit.
    The marked part is the entire adapter for M14(Primus 2000 system) - but you may find chinese adapters to connect american 1" bottles to the M14 valve unit.
    The old adapter system was used more than 40 years from early 1960's on.
  4. Jim Lukowski United States
    New Jersey, USA
    Angela,
    If you're still having difficulty sourcing what you need, I suggest dropping into your local propane dealer and ask them about making up a new hose with your current stove end adapter and the current propane bottle adapter. Not a dealer that only refills propane tanks, but one that sells and services propane appliances.
  5. Angela Dawson Canada
    Vancouver,, BC
    Thanks to everyone for your replies. I'll try every suggestion.
    Angela
