New member and how to remove stuck NRV when the NRV head is damaged.
Discussion in 'Stove Forum' started by Jack Tar, Mar 17, 2026.
  1. Jack Tar
    Jack Tar Germany Subscriber
    Germany
    Hello and good morning.
    I’d like to introduce myself as a new member.
    I’m a stove collector located in northern Germany. I’ve been collecting for many years, mainly Primus and Optimus.
    My favorite is the Primus 96 and its lookalikes (Radius, Optimus, Thermidor...).
    Many other stove models have also found their way into my collection.
    My fascination began with the Optimus 535 on my father’s sailboat when I was still a child.
    Now I’d like to share my method for removing stuck NRV valves when the valve head is already damaged and rounded off and any standard tools fail.
    For this, I made a tool out of chrome-vanadium steel from an pin punch tool. Using an angle grinder, I shaped an NRV wrench that is slightly hollow on the inside and has a sharp edge.
    2026-03-17-095832_002.jpeg 2026-03-17-095852_002.jpeg 2026-03-17-095937_002.jpeg 2026-03-17-100958_002.jpeg
    I clamp the tool in my bench vise and then place the stove onto the tool.
    By gently pressing the stove against the tool, I turn it, and the sharp edge bites into the softer brass and does not slip.
    Using this method, I have had success with all problematic NRV without having to desolder the pump tube or any drilling.
    2026-03-17-100032_002.jpeg 2026-03-17-100134_002.jpeg 2026-03-17-100214_002.jpeg 2026-03-17-100247_002.jpeg 2026-03-17-100318_002.jpeg
    I’m glad to have found this forum.
  2. Blackdog
    Dreaming of snow
    I like you already. Many problems can be solved with a 4 1/2" grinder (ok 115mm for those on the continent).
    Thank you for sharing your method, it's always a bad feeling when a pump valve won't come quietly and the more tricks we all have available the better. Welcome, I look forward to seeing some of your collection...
  3. Remus1956
    Los Angeles California
    Ive had to remove a few pumps to get sheared off NRV's...definitely not for the weak minded haha. Good tool!
  4. Sellig33
    Hi @Jack Tar ,
    Welcome aboard, and thank's for your solution !
    Regards.
    Gilles
  5. snwcmpr
    I kind of thought removing the pump to get to the NRV was initiation for membership here.
    I enjoyed my experience.
  6. Russenjesus
    Russenjesus Subscriber
    Bavaria Germany
    Hello Jack,
    and hello from Bavaria(Nördlinger Ries). Do you know the Pelam-Forum?
    When I see so demaged Screwheads, I ask me why not been changed earlier?
    Have a nice Day
    Markus(RJ)
  7. Jack Tar
    Germany
    There was a time before I invented that tool…
    2026-03-18-081956_002.jpeg 2026-03-18-082034_005.jpeg 2026-03-18-082034_006.jpeg 2026-03-18-082034_004.jpeg 2026-03-18-082034_003.jpeg 2026-03-18-082034_002.jpeg
    Hopefully, I passed the initiation on this second try.
  8. Andrew
    Port Elizabeth South Africa
    Heat the tool up a bit (not hot enough to melt solder) to transfer some heat to the NRV.
    This also helps loosen a stubborn NRV.
  9. Blackdog
    Dreaming of snow
    Do you think that would help, rather than just very slightly expand the pump valve body making it tighter in the end of the pump tube?
    My experience of a wide variety of old machinery is that heat only tends to be effective when both the male and female component have gone through at least one heat and cool cycle well above soldering temperature, ideally red heat where any chemical or oxide bond also gets broken down.
  10. Jack Tar
    Germany
    When using a standard NRV tool, I've been experimenting with boiling water and freezer.
    I could not find any difference. The NRV were still stuck.
    With my new tool, i just unscrew them, and they come loose with a jerk.
    No harm to the stove.
  11. snwcmpr
    Often the force needed to release the nrv can break the pump tube or tge soldered joints. No matter the tool used.
    Penetrating oil beforehand can possibly reduce the risk.
  12. hikerduane
    Plumas County, CA
    I heated one of my tools too much and the bottom of the pump tube dropped out, had to then unsolder the pump tube.
  13. Jim Easton United States
    New Zealand
    Hi. Like you Im glad to have found this forum. Your NRV removal tool, the cut out I presume is slightly less than 5mm. When this was done did you hammer one toe inwards and then shape with a file to a point.
    Thanks
  14. Jack Tar
    Germany
    I made the tool by eye and with a new NRV as a reference.
    The shape is made by tilting the cutting wheel only.
    There may be more professional ways to make tools like that, but it worked well for me.
  15. Jim Easton United States
    New Zealand
    Thanks for that info. I am a member of our local MenzShed so will have a go at butchering a punch, needs must, next visit. Hopefully I can let you know of a successful result.
    My collection at present; two PRIMUS 96, one PRIMUS 97 and a PRIMUS 100
    The 96 that I’m having a problem with belonged to my father hence my need to get it going again. Others have been donated.
  16. z1ulike
    @Jack Tar I've got a couple of stuck and rounded off non-return valves. Can make and send me one of your removal tools?
    If so, send me a private message and I'll gladly cover the cost of your work and the postage. Thanks.
