Nikkel Hovik Verk Primus 210
Discussion in 'Primus No:210' started by hikerduane, Feb 12, 2019.
  1. hikerduane
    Previous owner said he lived by the factory in Norway. Hovik Verk 210, made under license for Primus. Had been fettled before sold to me. Meths still in the container, so used some to prime the stove with. Some yellow to start, better flame after running 10 minutes, maybe old coating in fount or burner carboned some. Nice nickel sticker on the very clean tin. Incorrect spanner. Chained travel cap. Pricker pack has Hovik Verk on it, prickers are Primus. I've been wanting the Standard, but this will have to do.
    20190212_093836_opt.jpg 20190211_162629_opt.jpg 20190211_162731_opt.jpg 20190211_162843_opt.jpg 20190211_162646_opt.jpg 20190212_093503_opt.jpg 20190211_164601_opt.jpg 20190211_162237_opt.jpg 20190211_162219_opt.jpg 20190211_162229_opt.jpg 20190211_162506_opt.jpg 20190211_162826_opt.jpg 20190211_162332_opt.jpg
  2. Ed Winskill
    A real beauty, Duane. I really like the nickel stoves.
  3. shagratork
    Me too, Ed !
  4. ROBBO55
    A lovely little stove Duane. Congratulations :thumbup:
  5. Simes
    Simes Subscriber
    A fine example, worthy of anyones front room rather than the shed.
  6. Tony Press
    Another great stove, Duane.:thumbup:
    :thumbup::thumbup:
  7. Marc
    Marc Subscriber
    Oregon, USA
    Absolutely beautiful.
  8. hikerduane
    Thank you guys, stove goes in the garage for now, tin is too nice to put out there. Notice the depression in the priming cup to hold that last bit of meths. Really neat meths container, really think the cap is neat.
  9. Marc
    Marc Subscriber
    Oregon, USA
    Looks like the priming cup is much larger than would be normal for a burner that size. Am I seeing things?
  10. afoton
    Yes, that priming cup doesn't look like the right one.
  11. goldwinger11
    Merlin, Oregon, USA
    @hikerduane Isn't that depression for a lighting tube?
  12. Ray123
    Ray123 Subscriber
    New Hampshire, USA
    The spirit cup is the correct HV part. HV used a slightly larger diameter cup, which appears a bit shallower and with a dimple to make startup easier. Once all the spirit almost burns out there is still a flame at the dimple giving you a couple more seconds to start pumping.
  13. afoton
    It looks very wide on the pictures, but that can of course be an illusion. I have 2 Primus 210 made by Høvik Verk and both primer cups are 5cm i diameter.
  14. Harder D. Soerensen
    Denmark
    Nice one Duane - especially with the box as well!
  15. Tron
    Tron Subscriber
    Norway
  16. Tron
    Tron Subscriber
    Norway
  17. hikerduane
    Runs bluer today, more like 210, 00 should. Don't know if inside the tank had some coating, looks like oatmeal had been in it, leaving some of the goo behind. It isn't going anywhere, so that is fine. Off I go back to my cave.
  18. MrAlexxx
    Another one in good hands. You have all the cool ones!
    Alex
  19. Four Smokes Wallup
    Canada
