No 2 Modified Stove the Fife Fettle
Discussion in 'Fettling Forum' started by Surveyor, Aug 1, 2020.
  1. Surveyor
    Fife
    Having read enough on this forum especially the threads from presscall and the links to others, i have started the fettle, my first of 6 No2 and No2 modified and 4 Number 12 stoves, first thing was to take apart from the box which I intend to sand blast for the first one, I have sourced labels, bit pricey but may be worth it, i have sent every thing out as a picture from presscall and the Fettle Box, first issue was to get a spanner big enough for removing pump mechanism, visit to the local DIY, all washers were bone dry and have assumed parts were made of aluminium seemed corroded and needed side plyers on some parts to strip. IMG_20200801_151534.jpg IMG_20200801_151535.jpg
    This part seems needing a good clean will do with a damp cloth
    So far got to this stage need to get the rubber washers out
    Reading one thread I need to soak in oil the pump washer the one i have is made of Viton, so do i need to soak it?
  2. Lennart F Sweden
    Vänersborg, Sweden
    It is smart to lubricate Viton parts at assembly and if they are hard to fit due to stiffness, you could warm them a little to soften them.
  3. Surveyor
    Fife
    Many thanks was going to use olive oil as some one here recommended that on one thread which i cant find, just got all the springs and washers apart and spraying the tank. IMG_20200801_175033_1.jpg
  4. Wim
    Wim Subscriber
    Hi @Surveyor , your pump cup is NOT made of viton but is made of leather. The viton refers to the RUBBER seals & such. Best is to soak the pump cup in a mineral oil, vegetable oil gets rancid. Another good oil is neat's foot oil.
    Good luck with your restoration!
  5. Surveyor
    Fife
    Wim
    Thanks every day a school day and i dont mind, will look for mineral oil, may have some in a cupboard,
  6. Tony Press
    @Surveyor
    3-in-1 oil, or sewing machine oil will do. In desperation, use the dipstick of you car engine.
  7. Surveyor
    Fife
    Thanks was heading back to the store as my bottle didn't have enough, wonder why i started LoL
  8. z1ulike
    Sperm oil is best. Sperm oil has low viscosity and is very stable. It retains its viscosity in high temperatures better than most oils. It doesn't go rancid, gum up, dry out, or corrode metals. It also has a very low freezing point. It has been banned since the 1970's but occasionally some old stock comes up for sale on eBay. Expect to pay $250 for 8 ounces.
    The one pint tin of Sperm Oil was half full when I bought it. I bought another partial bottle that came from a 1910 pharmacy and topped it off. The tin has a really nice brass cap and is the stuff I use. The Brownell's is new old stock an has never been opened. I'll probably put it back on eBay in 5 years and see if I can't double my money.
  9. Surveyor
    Fife
    Seem to remember you saying that before, not sure of the availability of Sperm oil, got the 3 in 1 this morning giving it about a 30 minute soak then fit, after which burner to be refitted then the water test, as first one just hoping all goes well, i may need to get a washer for the burner unit as none in the pack.
  10. Surveyor
    Fife
    Found my first mistake unless you count forgetting oil and having to get "a bigger spanner", the leather washer for the pump does not have a perfect circle to fit, note to self next time check before putting it in oil.
    Please feel free to laugh
    Using this thread and as an aide memoire for me and notes for the first time Fettler on the No 2 modified and similar IMG_20200802_115751.jpg stoves
  11. Surveyor
    Fife
    IMG_20200802_134405.jpg Got the pump back together yes have pressure, next put back the bronze cylinder, spring seems to work, put that on now the problem, if finger tight when pumping the air will not escape, a slight loosening and the air come out via the threads.
    Any clues please? put it away till next weekend
  12. kerophile
    Hi, is it possible that you have assembled the NVR internals incorrectly?
    The rubber seal should be facing the pump piston once assembled:
    From this thread:
    NRV repair.
  13. Surveyor
    Fife
    Yes that's the way I have it, I am wondering if wrong washer in head but if that's the case the springs wouldn't move
  14. kerophile
    Hi @Surveyor there are slight differences between the NRVs from different Manufacturers and stove types.
    Here are a couple of photos I have just taken of the NRV from a Military No.12 stove, so similar to yours.
    487144A6-733E-42F5-836A-A31FF506B3DC.jpeg F22F0DB3-FDEB-4396-98B5-BEE87BB6E197.jpeg
    Can you confirm that your NRV is assembled like this one?
    Another tip: once assembled you can always test pump function using a glass of water and watching where the bubbles come from.
    Kerophile
  15. Surveyor
    Fife
    Yes that's the way, I have put it away for now as away for a week and will look at it next weekend
  16. Surveyor
    Fife
    Right back and had a thought, took spring mechanism out and them brass fitting on pumps okay, we are now down to the spring mechanism and the new rubber, looking at Kerophile's picture the rubber looks on mine slightly larger, will dig one out and try.
    I have found some one who can sand blast the main case hopefully pick up Monday, this one is a trial, i do have a really badly rusted one which will get the same treatment when confident, the others are in a pretty good condition to clean and see what they are like
  17. Surveyor
    Fife
    I have the answer at last, when looking in the small tube i noticed a ridge, the rubber was catching on that so stopped moving, hopefully can be seen in the picture, it was Kerophiles picture made me think and have a further look.
  18. Surveyor
    Fife
    Just put a pressure test on it, small leak around the pump washer, can fix that but bubbles coming through the small hole in the centre of thefiller cap all washers replaced here, is that normal
  19. Lennart F Sweden
    Vänersborg, Sweden
    Some times you will need to clean up the mating faces for the seals by scratching, filing or some other suitable method to allow seal contact all way around - the leak in center of filler cap is the SRV that should be air tight at normal working pressure and only open when max pressure is exceeded.
  20. Surveyor
    Fife
    Lennart, thankyou for that information i suspected as much the tank is empty and gave 6 pumps, just glad I worked out why no pressure to start, Need to dismantle the SRV again and have a look, I know when I started taking it apart everything was bone dry, no moisture in it at all, just having fun working out whats wrong and sorting, as said before you never know who is learning from me as I am learning and how many are going yes i remember doing that.
