NOS Optimus 111t international issues
Discussion in 'Stove Forum' started by WilliamH, Mar 17, 2020.
  1. WilliamH
    WilliamH Canada Subscriber
    Canada
    Thank you kindly for the replies. I look forward to making some percolated coffee on it this morning.
    I hope this is my last stove....I have over 15 now, and my bank account is hurting. It sure is addicting. Hahaha
    Take care,
    W
  2. snwcmpr
    snwcmpr Subscriber
    No hope for you if you already have 15.
  3. WilliamH
    Canada
    Hahahah.....
    Here is my collection: MSR: dragonfly, xgk ex, whisperlite international.
    optimus: Polaris, 00, 2x 111 and 111t
    svea: 123, 121x2, 105.
    enders: 9061 military
    Trangia: 25-21
    biolite and solo stove.
    Also, 4 vintage lanterns.....
    it’s very addicting and expensive!!
  4. WilliamH
    Canada
    On another note, I know methyl hydrate is very toxic to touch as it absorbs into the skin and metabolizes into formaldehyde. Other than that, is it safe to use in the trangia like bio ethanol would be? I am very aware of toxic gases like CO and the need for ventilation, but I’m wondering if other gases are released when burning methyl hydrate that are toxic.
    I want to use methyl hydrate because it’s 10x cheaper than bio ethanol.
    thanks,
    W
  5. JP2
    JP2 Subscriber
    Canada
    Very good question William, can not wait for an answer
    Here a good explanation on Alcohol.
    Do you have an alcohol stove by gravity? They work good !!??!!. Sorry this one was the last one. Lololo
    Turm-Sport old version
  6. hikerduane
    I wasn't that interested in lanterns, but have almost 50 now, not quite as many as stoves.
  7. kerophile
    Hi @WilliamH . Regarding you question about the use of Methyl Hydrate, please see this old post by BD:
    From this thread:
  8. kerophile
  9. Marc
    Marc Subscriber
    Oregon, USA
    I burn yellow bottle HEET in my Trangia. It's methanol, burns hot and clean, never any soot on the pans or percolator. Pour carefully to avoid skin contact, don't breathe the fumes, don't pour it over your morning cornflakes or put it in the baby's bottle. Not recommended, but I've had no issues.
  10. WilliamH
    Canada
    Good morning,
    Thank you again for taking the time to answer my questions.
    After using the 111t for the last couple days, the flame has changed to a more blue color, but there is still a section in the back where it's a little yellow. I'm sure after breaking it in further, the flame will all be a nice blue color. I am using K1 kerosene.
    Take care,
    W
  11. pysen78
    pysen78 Subscriber
    I've used methanol in Trangias many times.
    In pressure stoves you may have problems. I believe the mix may get too lean unless you play with jets or air restrictors.
    In automotive forums, I've heard people say it's corrosive to alloys in carburettors so maybe take extra care with pots and pans.
  12. WilliamH
    Canada
    Hey guys,
    sorry to ask about this stove again, but I’ve run into a new issue that I can’t figure out.
    I was trying to figure out why the flame was more powerful on the right side vs the left, so I took apart the spindle, jet and cleaning needle.
    After everything was cleaned and inspected, I put everything back together. I have tried tightening the spindle, but a flame still comes out from it telling me that there is a leak. The graphite packing seems to be in good condition.
    With the cleaning needle, I have tried 4-6 clicks, and when the spindle is fully turned clockwise(off), during warm up, the vaporized kerosene starts coming out of the jet and ignites. So off doesn’t work anymore.
    Any help would be appreciated.
    Thank you.
    W
  13. kerophile
  14. WilliamH
    Canada
    Thanks Kero, that helped out a lot!
  15. The Warrior
    In the 'Nois man.
  16. WilliamH
    Canada
    Thanks Guys!
    I took the entire stove apart, cleaned everything, replaced the graphite, and changed the cleaning needle to 3 clicks. The stove now is perfect. Perfect symmetrical flame, blue and powerful.
    Have a great day!
    W
  17. The Warrior
    In the 'Nois man.
    Congrats man, nice work.
  18. kerophile
    Hi @WilliamH . I am glad that you now have your NOS Op.111 operating as you would wish.
  19. WilliamH
    Canada
    @kerophile
    Thank you sir.
    One more question if I may: The fuel tank seems to heat up pretty fast in a manner of 10-15 minutes when I'm making my morning coffee. My heat shield over the fuel tank needs to be polished as its pretty dull looking right now. Would polishing it help with reflecting heat from the burner or maybe I can make an additional shield out of tin foil.
    Thanks,
    W
  20. kerophile
    Hi, @William. As long as the kettle or pot is not so large that it totally overhangs the stove base and tank you should be OK. There needs to be some heating of the tank to pressurise the air volume above the fuel in the tank. If you can still touch the tank without burning your finger you should be OK.
    You can certainly experiment with a layer of shiny foil added to the heat shield, but these stoves are very well designed and have stood the test of time.
