Hello guys im new here, got my Primus no1(AD)Silent for free and it didnt work right. Found out that it lost pressure from pump sylinder. Made a tool of an 13mm drill bit to remove NRV, worked like an charm. I replaced the original cork piece with a button from my old tv remote button Also replaced the original fillercap gasket(was so hardened) with a piece of bicycle innertube. Now the device works so good
It won't work for long. You need fuel resistant washers and pip, what you used may swell up and not seal. Duane
@Doni I'm sure that spare pips and washers are available on line in Scandiwegia but @Spiritburner via the Fettlebox (link in the right hand side panel) will be able to sort you out with a seals kit E which is for the No. 1 and No. 5 type stoves. Regards John
