NRVs with one-piece moulded pips (no holder)
Discussion in 'Fettling Forum' started by Macaroon, Apr 17, 2019.
  1. Macaroon
    Macaroon United Kingdom Subscriber
    I recently serviced the NRV on my Primus No. 2 and decided to reuse the pip because there was no pip holder, as it had one-piece moulded pip that fitted straight into the spring.
    The pip seems OK and I reassembled it and fired up the stove, which seemed to be OK and there were no leaks in the pump tube.
    However a few posts on this forum have made me wonder if I put the pip back the wrong way round! I inserted it into the spring correctly, so it sat against the spring, but does it matter which end of the NRV tube it sits against? (i.e. the slotted end or the raised end that you fit the removal key over) In other words, is there a wrong way round?
  2. Spiritburner
    Spiritburner Admin Subscriber
    Aye - pip needs to go upwards (towards the raised end)
  3. Macaroon
    Duh! Thanks @Spiritburner, sounds like I had a narrow escape!
  4. kerophile
  5. Macaroon
    Thanks @kerophile - great photos. I think I might have stumbled across this thread and aroused my suspicions from it!
