Hi here are some photos of an ex-British Army Optimus 111 Hiker. I have had this silent burner stove since 2009 and when using it today realised that I had never posted any images of it operating: Best Regards, Kerophile
I like that! The multi-fuel capability and silent burner make it a cut above your typical 111. Thanks for posting! Jerry
Hi @Gavin Mulholland .This model of copper kettle is one of my all-time favourites. It is model R52, Made by Tagus, Portugal. It is made for use rather than ornament, so is tin-plated internally.: Check out Tagus kettle on Ebay. Best Regards, Kerophile.
thanks! looks like someone chopped the case hole for the control knob shaft out with tinsnips rather than by design!
The British Military added a crude paint job to the civilian Op.111 and that was it! Best Regards, Kerophile.
Really nice specimen. One of the best versions of the 111 an with an interesting story. Doesn't it look like the hole for the control knob has been cut larger? It makes sense as the needlethreading of trying to poke the thing through the tiny hole in the case, is one of the weak points in the design. More so when you're a grunt suffering from mild hypothermia.
As a newbie I wonder - what is that aluminum sheet at the bottom of the case, under the burner - heat reflector?
@Jukka Pekka Hi, Aluminium foil is in place on both my 8r &, 111 stoves to stop HOT water & Fuel Spillage from messing the paintwork. It is easy to replace, & saves cleaning. Another good tip from scanning CCS. Best Regards, Optimust.
