Optimus 00
Discussion in 'Optimus No:00' started by Simes, May 31, 2020.
  1. Simes
    Simes Subscriber
    A stove I should have listed a long time ago, and I think the first time I've lit it since I acquired it.
    It's seen little use and there's a slight vapour leak at the riser seal, other than that a 00 doing what it should.
    All the bits.
    A nice tin that still had it's card wrapping
    Pack of.prickers
    The leg packet (?)
    Engraving, which is quite limited on this example.
    Up and running. The nipple needed some pricking to clear which may be the cause of the over rich burning, or it needs a longer burn to clear it's throat
    .Date I'm guessing as 60's at this point.
  2. ArchMc
    ArchMc Subscriber
    Mojave Desert, California
    It looks like mine, which I ordered from Optimus USA in the early 80s. No telling how long it had been on a shelf, though. Nice stove!
    ....Arch
  3. Simes
    Simes Subscriber
    @ArchMc, my dating guess is only based on one I have from the early 70's which is in a plain red tin and much simpler accessories, I'm unsure if Optimus changed to a more elaborate offering post this time.
  4. kerophile
    Hi @Simes Good-looking stove. Please will you provide photos of the lettering on the top of the burner and bottom of the fuel tank.
    Your Op.00 looks similar to this 1957 model I have:
    Optimus No.00L. Approx. 1957
    Please compare features and tell us how they compare.
  5. Simes
    Simes Subscriber
    Hi @kerophile, will do, apologies for the delay, I'm still adjusting to home working. :whistle:
    A previous owner I think had a problem at some point with a couple hints at someone who didn't know their way around the stove.
    The nipple is definitely worn as after clearing a blockage it's definitely running rich. It may be a candidate for a hypo fix as I've not done a standard .32 jet as yet.
    I'll try and get clearer images as the ones above were a little rushed.
    One thing I've yet to do is check the box printing for additional info, and although mostly complete the instructions, if supplied, have been lost.
  6. Ed Winskill
    My avatar is of course the 00, badged as a Primus 210, an aberrant designation I have always refused to recognize. I do have a couple of real 210s.
    But that dates mine, to be sure, though I do forget the chronology.
    My favorite and much-used 1-pinter.
  7. Simes
    Simes Subscriber
    Hi Ed, @Ed Winskill sorry my fat fingers spoiled a chance to chat Sat eve, I heard you mention our Pike Market meet with Gerry, sadly everyone had signed off before I figured out my mistake.
    I have a pair of 70's 00's as grab and go stoves which just seem to work whatever, it just feels wrong using anything else on long trips.
  8. Big Si
    Big Si Subscriber
    @Simes get rid of that rubbish mate and get Shinabro, you know it makes sense. The 340 is one of the best stoves you could ever want to own!
    Si
  9. Ian
    Ian Subscriber
    West Yorkshire
    Si has it nearly right; get a Shin 340 as well. ;)
  10. Simes
    Simes Subscriber
    Ok, ok....you've talked me into it. :roll:
    Another stove I didn't realise I 'needed'. :D
  11. Big Si
    Big Si Subscriber
    @Simes I think @Ian will be referring to one of these as they are one of the best stoves in the world. (Say that in your best Jeremy Clarkson voice)
    Shinabro Royal 400c
    Si
  12. Ian
    Ian Subscriber
    West Yorkshire
    One of them, too! ;)
  13. Simes
    Simes Subscriber
    Apologies George, @kerophile I've been a bit busy looking for a Shinabro.
    The tank bottom and burner details are identical to yours in the link. The burner has both types of script and tank base has Upplands Vasby stamped. The cardboard box has 'Travelling No. 00' printed, with the 'L' hand written as usual.
    Puts the stove in the late 50's early 60's era.
  14. kerophile
    Hi @Simes. Many thanks for making the checks. These are great stoves. Powerful yet compact.
  15. CRAZY CRAB
    addlestone
    got one, but i need to get the NTV thingy out, got it to unscrew, that was easly, but it wont fall out :(
  16. kerophile
    Retrieve o-ring in pump tube
    Another suggestion was to put some pressure in the tank using a water hose via the filler tube, or use an air-line if you have access to one.
  17. kerophile
  18. Harder D. Soerensen
    Harder D. Soerensen France Subscriber
    Denmark
  19. CRAZY CRAB
    addlestone
    forceps seens like the best idea, local dentist seems like a realy good idea, pull this Sir :)
