Optimus 11 with roaring burner.
Discussion in 'Optimus No:11' started by Skauvill, Aug 25, 2019.
  1. Skauvill
    Skauvill Subscriber
    Innlandet, Raufoss
    For several years now, I have spendt time with iritation over some real unnatural scratches on the top of the box. I think patina is nice, sure, but when somebody make unnatural scratches I finally decided to make a repainting. I also make a new burning test . I think the color fits well the original color. But I need to admit that the paint are not type heat resistant. So if anybody have contacts, buying color with heat resistant,
    Matching this and other color, I should be happy! Example millitary green, RAL 6003, and yellow olive green. Must be in spray cans.
    20190825_105145.jpg 20190825_101427.jpg 20190825_101415.jpg 20190825_101305.jpg 20190825_103613.jpg 20190825_101349.jpg 20190825_100543.jpg
  2. SveaSizzler
    Tucson, Arizona
    Hi Skauvill,
    I don't know if Rust-oleum paint is available outside the USA, but they're a pretty big brand, so I would guess it's more than likely.
    I use Rust-oleum High Heat #7752 Heat Resistant Green for my Sunbeam gas BBQ grill.
    SKU: 020066775285
    It's a special spray paint for stoves and high heat applications.
    The color is sometimes called "Hunter Green.'' It has a semi-gloss or matte finish. Some Coleman appoliances of a certain vintage have a similar shade.
  3. geneislucky
    I appreciate the old being restored to look and work like new. Good luck with your search for suitable paint.
  4. snwcmpr
    I used Charleston Green for my 11 and 8.
  5. Skauvill
    Skauvill Subscriber
    Innlandet, Raufoss
    Hello! Thank you for feedback! Does it look like the original color? Do you have any pictures?
  6. Skauvill
    Skauvill Subscriber
    Innlandet, Raufoss
    Hello Sveazziler! Thank you! I will look it up in a colormap to see what it's like!
  7. snwcmpr
  8. JP2
    JP2 Subscriber
    Canada
    Hi, it seem that many do like you and add a high temperature clear coat over it to protect the paint and it works good.
  9. snwcmpr
    I did not clear coat. I let the paint cure at least one month.
  10. Skauvill
    Skauvill Subscriber
    Innlandet, Raufoss
    JP2 and snwcmpr
    I think it`s the best, if it`s possible to use heat resistant colors. I have a couple of insident from years ago, using regular Paint for cars. The painting was melting under the tin Box (optimus 8)
    But sure it`s help letting it hardend for some month.
    Does anybody try to hardend it in the oven for at least 150 degrades?
  11. Skauvill
    Skauvill Subscriber
    Innlandet, Raufoss
    snwcmpr
    I have posted reply on Your links to Optimus 8 and 11
    Thanks for showing!
  12. Skauvill
    Skauvill Subscriber
    Innlandet, Raufoss
    geneislucky
    I do agree with you! Thats why I think its important to find the right color, actuelly not easy, but I like to try. And offcourse its makes it even more difficult when trying to find heat resistant as well.
  13. snwcmpr
    I did bake to cure first. But I left the painted stove to hang for a month.
    @ArchMc Any paint coming off?
  14. JP2
    JP2 Subscriber
    Canada
    Hi, here my 111 that look almost same at yours, the paint is from Napa and it is a high temperature one, oil and gas resistant. I also bake it following @Tony Press recommendations.
  15. Skauvill
    Skauvill Subscriber
    Innlandet, Raufoss
    Jp2
    Thank you so much! This color are similar to the color on my 11. All my 111 have nos or nearly nos boxes! I am happy to say! I will try the baking metod on one of my Fuhrmeister 8, as I decided to paint restore.
    Thanks again!
  16. Skauvill
    Skauvill Subscriber
    Innlandet, Raufoss
    I also need to buy this color! Not availible from eBay ship to Norway from anybody[​IMG]
    BS381-220 militært olive green heat resistent. Where to buy?
  17. kerophile
  18. Skauvill
    Skauvill Subscriber
    Innlandet, Raufoss
    Kerophile
    Thank you! This was good help! Hopefully it will be possible to buy it for shipping to Norway. Also hopefully, they can deliver it in spraycan
    Br Skauvill
  19. ArchMc
    ArchMc Subscriber
    Mojave Desert, California
    Nope! Still looks great.
    ....Arch
  20. snwcmpr
