Optimus 111 Embossed
Discussion in 'Optimus No:111 (all variants) + later Hiker & Hike' started by Cesar, Apr 30, 2021.
  1. Cesar
    Cesar Chile Subscriber
    Chile, Southamerica
    20210429_223805.jpg 20210429_223819.jpg 20210429_223819.jpg 20210429_223830.jpg 20210429_223836.jpg 20210429_223842.jpg 20210429_223856.jpg 20210429_224237.jpg 20210429_224422.jpg
    Dear friends, thank you for accepting me in this prestigious forum. Here , my first publication with this beauty that I have wanted for many years.
    Optimus 111, I intend to do a general cleaning and then turn it on although, as can be seen in the photos, it has missing parts:
    Jet
    Claning needle
    Both steel supports
    Windscreen (I don't know if this model originally came with it)
    I would like to know the approximate date of manufacture according to its characteristics.
    I would also like to know what the measurements of the cooking supports are to try to make them (I have some experience solving problems with paraffin pressure lamps). And of course i need the injector and the needle, do you have any link for bought them?.
    Thank you very much again for reading my long lines with a somewhat rustic English.
    Cheers from Chile, Southamerica
    Cesar
  2. kerophile
  3. Cesar
    Chile, Southamerica
    @kerophile Thank you for your welcome, I appreciate it very much.
    I will try to buy the jet and the needle, I do not know if I also buy the burner adjustment kit, visually it is fine, but maybe there is something I do not know about its internal wear.
    Could you share some measurements of the cooking supports? Maybe there is a tutorial to make them, I think a good wire could work, but I would like to know the diameter, the length and width.
    Maybe someone can have these cooking supports and the windshield available, used of course. They seem to be common parts with other cookers.
    Cesar
  4. kerophile
    A37A3DAA-7BEB-4EF4-A188-A3E6AF7B74DC.jpeg 9737742C-9965-42F1-8D0F-674178E04B42.jpeg C1E03060-46BB-4B82-81B1-0731C6A6D0DB.jpeg B472DCFA-6C46-4D44-B42A-1DEECB2AF9A5.jpeg 425CD04D-CEDF-402F-9C3A-9D9ADFA8B4A5.jpeg 0FEA7A6F-F333-4D50-AC2B-441E902E3530.jpeg Hi @Cesar . Here are some photos and dimensions of pan support from a 1950s embossed Op.111:
    Graph paper is mm x mm
    Support wire diameter in 4.5 mm diameter.
    Flat section is 3.8 mm x 4.5 mm diameter and the flat surface is on the outside surface
    Material in Ni-plated mild steel and quite stiff.
    Tutorial on making replacement stove legs:
    Making Replacement Legs
    Most important part is to support the steel rod in a tube when making the bend.
  5. Cesar
    Chile, Southamerica
    @kerophile you are awesome! This measurements will me fly!
    Thanks a lot
    Cesar
  6. Ed Winskill
    Welcome to CCS.
  7. ROBBO55
    Welcome to CCS @Cesar
    It's a great looking stove and should clean up nicely :thumbup:
