Optimus 111 flame is not correct
Discussion in 'Fettling Forum' started by Tantra, May 17, 2019.
  1. Tantra
    As I post the photo
    I have changed two nipple
    No use
    How to do my flame
    Thank for all.
  2. kerophile
    Hi @Tantra you need to eliminate possibilities, one at a time.
    If you get this pattern with two good jets, it might suggest that the jet is not the problem.
    Next test is to remove the cleaning needle, and then run the stove without its cleaning needle. If the poor flame pattern continues it suggests that the cleaning needle is not to blame.
    You should then check that the burner is not distorted and that the jet is centred directly under the centre of the vaporisation chamber of the roarer burner.
    A partial blockage of the tubes or vaporisation chamber of the burner is also a possibility.
    Tell us what you find.
  3. Mark Layman
    Mark Layman Subscriber
    USA West Virginia
    I suspect a very small leak where the nipple seals. Not enough escaping to burn at that location but enough to disrupt the air flow caused by the vapor rising. I have had this happen. I dressed up the seat on the burner.
    Look at it with a magnifier with the nipple removed and look for small pits in the brass seat. It can be dressed with a needle file but carefully.
  4. Tony Press
    @Tantra
    I note you don’t have a flame ring fitted to your burner.
  5. Mark Layman
    USA West Virginia
    No flame ring doesn’t make the one sided yellow burn. Efficiency is greatly degraded without one but it should still burn even blue without.
  6. Tony Press
    I wasn’t implying that the flame ring would fix the lopsided flame; just noting its absence in case he did not have one.
    The previous advice is worth following.
  7. Tantra
    I have but I am not like use flame ring
    I like flame regularly as flowers.
  8. Tantra
    I agree I always want to everything perfect.
  9. kerophile
    Hi @Tantra please will you confirm that this is a kerosene fuelled Op.111 and not a gasoline Op.111b.
    Just checking.
    111 vs. 111B
  10. Tantra
    Kerosene I know yet
    Four legs and two legs. They are not same burner.
  11. Tantra
    I have many 111. Another 111 stove have perfect flame.
  12. Tantra
    I
    have removed the cleaning needle,nothing happened same as before
    Now I have put the stove to the soup water,I hope I can obvious somewhere leak in the burner.
  13. HunterStovie
    Parker, Colorado, USA
    @Tantra
    What condition is the screen/strainer/wire mesh in the fuel tube?
  14. Tantra
    image.jpg Yes I find what was wrong on the burner
    Yes it have leak and repair long time ago
    Thank you for all
  15. Tantra
    Yes the burner have small leak.
