Optimus 200.
Discussion in 'Optimus No:200' started by Driftwood, May 24, 2023.
  1. Driftwood United Kingdom
    Kent, England
    Latest project. Box is ok apart from the catch is broken. Stove is in very good condition, meths can is ok. Legs are not original I think. Windshield and spanner missing.
    I changed the washers , could not get the nrv out as it would not release and I was a bit scared of damaging the pump unit , so it is in soak for now.
    Fired up with a long pre-heat and ran well, made a brew so good to go for now.
    Will get some better pictures later.
    389BFDBB-AB04-427A-BD40-039DE4EC946D.jpeg F7126772-AB46-4F7E-8C6E-4B1F6EC25488.jpeg 49E473D3-9532-4491-A4D6-5B9B508E9ADF.jpeg 1D03C1B0-FAE3-4869-B59B-3857AB47DF34.jpeg 24EA89C9-21AA-4810-8398-66D7DCFEECE5.jpeg FD07EBED-052E-44C0-A960-E9AC4F3BD237.jpeg 2172927C-EDA1-48D9-A16E-D09FB01004A5.jpeg 2994EFFB-11B4-4F1F-B05A-21FD3DF0A7C9.jpeg
  2. Driftwood United Kingdom
    Kent, England
  3. OMC
    OMC United States Subscriber
    Thank you. Very nice.
    Trevor's Hyperlinked Index has 1 pint (travelling) 200 spanning 1915-34.
    The latest offering for the 200 is 1934 (model had ended by 39 for sure).
    So far my guesstimate is pre-32 for this one. That said it could just as well be 1924 or earlier.
    That looks to be the original tin, the tin may place it even earlier :-k.
    The backdating so far:
    the 1 pint tank details for the 200 & 00 are similar. Catalog illustrations can be flawed but the '34 and 32 catalogs still shows 200 side tank markings as you have:
    Globe logo on left then "Aktiebolaget Optimus Stockholm".
    on top, "Patent" is still in use in 34 (and beyond).
    ('29 brochure not sure that helps).
    '24 catalog reflects a change.
    Sometime pre-32 (after 24) the use of your hex reserve cap ended.
    thanks again
  4. Driftwood United Kingdom
    Kent, England
    @OMC thank you for that information.
    That makes it the oldest stove I own.
    I am giving it a gentle clean at the moment as there has been water in the bottom of the box and the legs and flame plate have a little corrosion on them.
