Optimus 324
Discussion in 'Optimus No:324 Rider' started by fyrwokr, May 12, 2012.
  1. fyrwokr
    fyrwokr Subscriber
    Bitterroot Valley Montana
    This one came with the box, no instructions. A really good friend found this one for me.Doesn't look like it was really used. After trying to pump up tank realized the pump valve has a massive leak, will have to remove the valve set and see what is wrong. Will have to build a wrench first. I have read good and bad about these on this forum. Can't wait to try it.
  2. yonadav
    Israel
    Congratulations!
    I have a similar stove that leaks at the control valve stem. Got some parts for it, and will try to fix it when I find the time.
    Yonadav
  3. snwcmpr
    Yonaday,
    Do you have an update on your leak at the valve stem?
    I just got one with that same leak. Would appreciate you doing all the heavy lifting, and leaving the easy part for me. LOL!!!
    Ken in NC
