Optimus 535 Pulsing question
Discussion in 'Stove Forum' started by lazystar, Sep 8, 2021.
  1. lazystar
    Hello everyone!
    My Optimus 535 has recently starting slightly pulsing a bit ,as well as it will sometimes blow out after pre heat. After checking around the forum , I'm thinking some rolled up brass mesh may do the trick.
    Does anyone know where I can find some? Also , any other advice would be greatly appreciated.
    thanks!
    Jonny
  2. ally
    ally Subscriber
    Lincoln, UK
    watched this the other day, might help
  3. lazystar
    Thank you so much Ally! This looks to be exactly what is going on with my 535.
  4. hikerduane
    Plumas County, CA
    Base Camp has pre cut mesh.
  5. ally
    ally Subscriber
    Lincoln, UK
    I liked the casual talking as the tank is exploding!
    It's a lovely looking stove, would be nice to use it properly
  6. Dutchmike
    Netherlands
    As the 'tank is exploding'? That video by Bernie Dawg is a tutorial, not a video game. I wish people would stick to facts instead of hyping nonsense which does nothing to improve knowledge and ultimately safety. The casual talk might be explained as this person has that (extensive) knowledge and is not fazed by some flare ups. So should we all, and learn from each other based on facts and make no undue drama about it. Mike
  7. ally
    ally Subscriber
    Lincoln, UK
    I'm sorry I upset you mike
    please advise me of the correct term for an explosive event in a fuel tank of naptha and I'll edit my post
    I will also try to be more forthcoming and definite with my smiling emoticons, I will see if I can find one with it's tongue in it's cheek
  8. hikerduane
    Plumas County, CA
    I guess I missed the explosive part. We all been chastised I guess.
  9. Scrambler
    Australia
    Ally, it's vaporisation in the fuel supply tube, pushing heated fuel vapour back into the tank.
    It would be equally accurate to describe boiling water as "exploding" as bubbles of vapourised water come to the surface.
    The noise is fuel vapour (like steam) bubbling back into the fount. The tank itself is heating from this boiled (hot) fuel coming back. Nothing is detonating, exploding etc. It is simply bubbling slowly. There is a pressure drop in the fuel line that causes the flame to dip, but there is no oxygen entering the line, just a brief near-absence of fuel vapour at the burner.
    I haven't gone back to listen to BD. If he says "exploding" I would assume him to mean "popping" as a sound.
  10. Kiwi NZ
    Kiwi NZ Subscriber
    New Zealand
    I have learned a lot from this post, thank you @lazystar for asking it. I have two 535's and did not know that they have a mesh restrictor.
    I will know where to look if they start to play up.
    And yes, the word explosion was used several times in the video, possibly not the most accurate description but that is what BD said.
  11. Dutchmike
    Netherlands
    It seems I took the wrong angle on a word game then. Still, I read 'explosive tank' which has nothing to do with anything shown or said in the video, so I took the comment from Ally as a needless excitement not helping a look on technicalities based on fact. That's all. Mike
