Optimus Campingo - safety issues?
Discussion in 'Stove Forum' started by Robert Radcliffe, Nov 5, 2019.
  1. snwcmpr
    That is IF I could get away that long. :)
  2. theyellowdog
    I am not good with pistols. The other shooters always get me when I am at the tap refilling mine.
  3. janders
    janders Subscriber
    When/if you guys are up to speed on how to figure out and battle what lurks in the depths of the Hobbit hole - I could use some help and that expertise....
  4. Garth
    My campingo has just arrived Small control version, the lid hinges have been damaged in the past and replaced with cupboard hinges. These do not work well at all im hoping a campingo owner may be able to provide a close up shot of the original setup, meanwile i will try to remove the ugly hinges from my case. Also the tank bracket has detachd from the front cover which should be easy to put right. Ive not investigated the main heat producing parts but all looks good there and a good spares kit came with the stove i cluding spindle packing and nrv kits i just need to tidy the case up a bit
  5. Simes
    Simes Subscriber
