Optimus No:11 Silent
Discussion in 'Optimus No:11' started by anfeng, Aug 3, 2019.
  1. anfeng
    anfeng SotM Winner Subscriber
    This is the version of the silent burner of optimus No 11 86296502-C277-48F5-A052-08BD24D43F9B.jpeg The picture below is what I got when I got it. 9A28192F-C0A1-400D-803E-FA97DE193803.jpeg I have rusted the outer casing. AF55FF32-2A56-48AF-A29E-C27C5F521BFA.jpeg 63B32471-284A-492E-8054-5AA39573EB8A.jpeg 230210CF-4347-469C-BC7F-9FE34F100870.jpeg 6B8AC80B-FAE5-419C-B288-AA00E73B28EA.jpeg The optimus globe logo in the middle of this version cover is a raised spherical relief 345A7914-3557-44DB-872C-B0519A296192.jpeg Dismantling, cleaning, maintenance 22BE19B0-F6F2-4B9F-8E50-CCFEC246A3CF.jpeg Tank lid pressure relief valve sealing element uses natural cork material 78B398E7-5A1B-4CDC-996C-048F6C1BA5D1.jpeg Special shaped needle F5ECD588-F32C-4643-8249-E7F794DFE8D3.jpeg Gas pump check valve also uses natural cork 5702AAD4-68D3-44AF-835E-8DD10B64E80B.jpeg A variant based on the optimus 207 burner E3BF53AA-89D5-4A5C-8066-07EF91C5E9EB.jpeg 445AE804-3166-4BE7-835F-9D2097885A18.jpeg The end of the valve shaft appears to be hand-formed 87B89602-40F5-4D6E-A227-F3E13B68794B.jpeg The preheating igniter is not available in the later version 111T. 0CF553D2-3779-4ABD-A085-72B3F4461E7C.jpeg The valve shaft is on the right side of the needle, and it is relatively simple to install the needle. It is enough to close the valve clockwise and then insert the needle. The needle is exposed when the valve is closed
    The connection between the fuel tank and the iron box is also relatively simple, without bolts. 96336F40-ABBE-42AA-B9E5-5999A7A79BB4.jpeg 19C5135D-9367-4B5D-9C89-C2A0DBD1A471.jpeg DEFA1640-44E4-4AE4-8726-37EC4AC5F589.jpeg
  2. anfeng
    Starting with the ancient ancestor Campingo, and the development of optimus 11, three different versions, and the early version 111 E5541666-F015-4C02-9D88-312815FB271D.jpeg 7D4D7A08-63E0-46A2-81A7-EBE79433BF49.jpeg 30F6930D-3D8A-427C-8B94-A21F70031E08.jpeg 55B312D0-BC8F-41DF-8498-FCE4F22A9F9F.jpeg 2CFF29A8-772E-4FD6-8568-CA83305479BE.jpeg 85918855-9BBD-4D1E-97E5-BF03A7D01B27.jpeg 5CD9EFA3-2AC0-4B6A-9B15-5B6A0B8C72CE.jpeg A3CB0D39-1684-4957-820D-4E95BDDC3207.jpeg
  3. snwcmpr
    Very nice. :)
  4. boknasild
    boknasild Subscriber
    @anfeng
    A beautiful collection you are showing us. Thank you.
    Bjørn
  5. ROBBO55
    Wonderful detailed post of the Optimus 11. :thumbup:
  6. Tony Press
    Excellent stove and an excellent presentation.
    Thank you, @anfeng.
    Best regards
  7. Robert Bruce
    Springrange NSW Australia
    Great presentation, thank you for this.
    Rob
  8. JP2
    JP2 Subscriber
    Canada
    Very nice and well done
    I like to see the pump at the front, il is more practical. Is there any specific reasons why they moved it on the side
    Thank for sharing
  9. burny pyromaniac Netherlands
    Arnhem
    I' not sure, but I guess that from the side a longer pump assembly is possible and a longer stroke means less times pumping.
    Regards, Tonio
  10. Staffan Rönn
    Stockholm, Sweden
    Really nice posting @anfeng and a beautiful collection.
    Does anyone know if this silent burner ever existed or if someone handy in brazing/soldering has made a one-off?
  11. kerophile
  12. Staffan Rönn
    Stockholm, Sweden
  13. anfeng
    @Staffan Rönn Except that the end of the valve shaft appears to be handmade, the other parts should be factory processed.
