Optimus No. 7 cutaway display, 1930's
Discussion in 'Optimus No:7' started by Staffan Rönn, Jan 2, 2021.
  1. Staffan Rönn
    Stockholm, Sweden
    This is a cutaway display model of Optimus No. 7 with burner 207 from the 1930's. The number on the tank is in the cut-out section, but I am assuming it's the same as the No. 7 presented in this catalogue: https://classiccampstoves.com/threads/1934-catalogue-no-1260.31160/
    These cutaway displays are excellent for showing the design and function of stoves. This one has an early generation 207 burner where the cleaning needle is in the upper position when the burner valve is closed. Other time markers include: tank bottom and side embossing indicate "Stockholm" instead of "Upplands Väsby", air screw is marked Stockholm, dimpled spirit cup and old style cookie cutter with tactile lettering.
    20210101_153518.jpg 20210101_153542.jpg 20210101_164558.jpg 20210101_152852.jpg 20210101_152910.jpg 20210101_152943.jpg 20210101_153015.jpg 20210101_153023.jpg 20210101_153124.jpg 20210101_153159.jpg 20210101_143608.jpg
  2. Metropolitantrout
    Santa Cruz, CA
    Well done. Thanks for posting this! Jerry
  3. orsoorso
    orsoorso Subscriber
    just corious, it seems to me that the jet cleaning needle rise up whem the spindle is turned clockvise, to shut off the flow.
    Am I wrong?
  4. Staffan Rönn
    Stockholm, Sweden
    Hi @orsoorso - You are correct. This is how the first generation of regulating burner 207 was designed. I don't know exactly when, but fairly soon the design was changed to clear the jet when the valve is fully open instead of closed.
  5. kerophile
    From 1939 Optimus Catalogue:
  6. Staffan Rönn
    Stockholm, Sweden
    And I also have a cutaway sample of a 207 burner of the later design where cleaning needle is retracted when burner valve is closed:
  7. Spiritburner
    Very informative & great display piece! :thumbup:
  8. BradB
    Central North Carolina USA
    Thanks. I have an early burner with the needle up when in the closed position. It is on a 1S with the lion paw feet. Beautiful stove! Brad
  9. ROBBO55
    Thanks Staffan, a very useful post. :thumbup:
  10. z1ulike
    Wow, I didn't know Optimus painted the inside of their stoves red.
  11. Tony Press
    Excellent display. :thumbup:
  12. Staffan Rönn
    Stockholm, Sweden
    Hi Ben,
    Yes - the red insides are quite intriguing. Maybe you could help us find out if this was the case also on other models from around the same era? What about cutting the tank and burner open of this one French Optimus 9 (not Halmia) and post photos for all of us to see here? :twisted::twisted::twisted:
