Optimus No.8 help with dimensions of the pot support
Discussion in 'Stove Forum' started by kok, Sep 22, 2022.
  1. kok
    kok Switzerland Subscriber
    Geneva, Switzerland
    Hello, Ihave an Optimus 8, but the stands are missing...if anybody could give me the dimensions to make new ones ...
    Thanks in advance
    Olivier
  2. Svea106 United Kingdom
    Bedford, UK
    did you take a look in teh refernce gallery to get an idea? 6mm galvanised steel tent pegs could be used for the basic material. I just made one for a Primus 96 although a smaller diameter for a smaller stove.
    I also used a blow-torch to get the metal orange hot for bending in a vice.
    You will end up cracking/burning the zinc coating but that's inevitable i think.
  3. kerophile
  4. kok
    Geneva, Switzerland
    Hi
    my optimus 8 says REG No 801106 and swedish pat no 71018 on the front, nickel plated, seams an early one.
    Thanks in advance
    Olivier
  5. kok
    Geneva, Switzerland
    2 pictures of my optimus 8
  6. kerophile
  7. kok
    Geneva, Switzerland
    Thank you svea 106 for your reply, Do you think stainless steel would be a good choice?
  8. kok
    Geneva, Switzerland
    Thank you Kerophile, best regards
    Olivier
  9. kerophile
    D9A21A4A-3594-4D87-871A-7F0214C522D6.jpeg Hi @kok I found my green case Optimus 8 today.
    The stove is fitted with two pan supports, which are goal-post shape.
    Material is mild steel but SS would also be suitable. The section is nominally 3.5mm diameter.
    Horizontal section is 120mm long, measured to outside of curves.
    Vertical height is 75mm, again measured to outside of curve.
    Each vertical has a flattened section extending approx 35mm from the bottom of the verticals. The flat section is on the outer surface of the verticals, the inner section is curved.
    At the point of the vertical the section is 2 mm x 4.8mm, at the mid-point it is approx. 2.5mm x 4.6mm, tending towards circular as it meets rod.
    Trust this helps.
  10. kok
    Geneva, Switzerland
    This helps a lot!
    Thank you Kerophile
    Best regards
    Olivier
  11. snwcmpr
    There is an old thread here of a member forging the flats on pot stands with weights.
  12. kerophile
  13. snwcmpr
  14. kok
    Geneva, Switzerland
    Thanks
    A lot of tools to make....
  15. kok
    Geneva, Switzerland
    Done!
    Thank you all for your help
  16. snwcmpr
    Nicely done.
  17. kok
    Geneva, Switzerland
    Thank you snwcmpr, I m not totally happy with the tool... The cover is too thin and too soft for the pressure of the press
  18. kerophile
    Hi @kok Looks impressive! Did you use mild steel or SS?
    How does it fit on your stove?
  19. kok
    Geneva, Switzerland
    It's ss, 4mm A4
    The stand fit perfectly on the stove, but I had to adjust the flattened end to a cone with a file. The second one will be more demanding to adjust the final height.
    I ll send photos of the stove after repaint.
    Please excuse my bad English.
    Best regards
    Olivier
  20. snwcmpr
    All good. It is excellent.
