Optimus No. 8 (Nickel)
Discussion in 'Optimus No:8 (version prior to the 8R)' started by Tony Press, Apr 10, 2019.
  1. Tony Press
    This fine little stove came to me from Harder in a stove swap.
    The stove was cleaned and fettled, not re-painted, but the tin was protected by a matt clear coat after cleaning.
    "Optimus/Made in Sweden/No. 8/Reg. No. 801106" (Note that "Optimus" is at the handle end not the hinged end of the stove tin).
    "Swedish Pat No.71018"
    Note that the stove has lost its spot-welded clip in the lid to hold a pricker.
    Note that the fuel pipe does not come from the bottom of the tank like earlier models of this stove, and is central to the long axis (not offset).
    The tank lid is not the earliest lid design for these stoves.
    Testing:
    Preheating.
    Blue flame.
    Test boil.
    No soot on bottom of pan.
    The test rig.
    But, I did notice a very small occasional flame coming from the point where the burner feed tube enters the tank. So I unscrewed the burner from the tank.
    The wick and the mesh were fine. I replaced the burner with a drop of Loctite (medium strength). IMG_2702.jpg
    I made a spill tray for the bottom of the tin (under the burner)
    All up a fine stove!
    The late Bryan Miller proposed a a tentative sequence for "pre-PTC" Optimus 8 and 8R stoves, here:
    PRE PTC OPTIMUS 8s & 8Rs
    Subsequent to Bryan's post there has been much additional information and discussion posted here by a number of Members.
    In this thread of Duane's, OMC produces a list of Primus No. 8 types. My stove is similar to this stove of BernieDawg. That would put it somewhere near the 3/4 mark in the sequential variations of the Optimus No. 8.
  2. Harder D. Soerensen
    Denmark
    Looks great @Tony Press
    You cleaned it up and presented it much better, than I would be able to!
    I miss the older arrangement under the burner on the more modern 8R.
    This old design doesn’t transfer nearly as much heat, as when the spiritcup rests directly on the tin bottom.
    I think we did a swap with two winners :-)
  3. MrAlexxx
    MrAlexxx Subscriber
    Very nice! On my MUST GET ONE list!
    Alex :)
  4. hornillo
    tarragona
    good flame, I have one but the bronze tank, I dare not touch it, the previous owner already tried it, left a mark on the tube and folded it a bit. It's more beautiful live :-)
    regards
  5. ROBBO55
    G'day Tony, it's running well and you have cleaned it up nicely. :clap:
    A good post as usual. :thumbup:
  6. Tony Press
    I noticed I made a mistake above.
    Correction here:
    In this thread of Duane's, OMC produces a list of [Primus should read] Optimus No. 8 types. My stove is similar to this stove of BernieDawg. That would put it somewhere near the 3/4 mark in the sequential variations of the Optimus No. 8.
