Optimus Nova problem
Discussion in 'Fettling Forum' started by Notso9bit, Jul 8, 2020.
  1. Notso9bit United Kingdom
    Norway
    Hello. I bought the Optimus Nova and used it one time, it worked fine and I used it to cook something.
    Then the next day I tried to fire it up again and no amount of pre-heating would get the flame to turn blue etc. It just shoots a pillar of gasoline into the sky, one straight line (not a mist). I tried all the troubleshooting things in the manual such as cleaning the nozzle, proper pre-heating, etc.
    I am pretty sure the fuel bottle is building pressure because there is resistance after 20-30 pumps. I have only used gasoline in it and nothing else.
  2. snwcmpr
    snwcmpr Subscriber
    Welcome.
    I would first ask about how you are preheating.
    And, if you are opening the valve slowly, or quickly?
    You have bottle pressure.
    You have a clear jet. (Did you use the magnet to toggle the pricker?)
    Double check the fuel.. ?
    Photos always help.
    Ken
    (Edit: I missed the part of spraying into the sky. As said below, is there a flame plate?)
  3. Staffan Rönn
    Stockholm, Sweden
    Also check that the burner plate (top plate / flame spreader) is in place. If fuel really shots into the sky, then it sounds as if this part is missing.
  4. Notso9bit United Kingdom
    Norway
    Yes that part was missing on arrival. I thought that was odd when looking at the manual.
    To preheat it I am letting some gasoline out, turning it off, lighting the escaped gasoline, and once it is almost out, slowly turning it on again. But this just either puts out the flame, or creates a large yellow flame pillar into the heavens.
  5. Notso9bit United Kingdom
    Norway
    But I am unsure what you mean to check the fuel? It is gasoline I bought from the gas station 3 or 4 days ago, theres nothing else in it.
  6. snwcmpr
    snwcmpr Subscriber
    You need a flame plate. A requirement.
    Good of @Staffan Rönn to note the key word "sky".
    After that, what you are doing should work. The flame, when spread properly by the plate, will heat the fins and properly vaporize the fuel.
    Gasoline from the gas station usually has additives that are not recommended.
    A Norwegian might advise better fuels to use in your area.
    If you fix the above problem, the stove should work even on auto fuel.
    Ken
  7. Staffan Rönn
    Stockholm, Sweden
    In any event, your stove will not work without the burner plate. This part is critical to the function. Maybe it just fell off in the stuff bag or so?
    Ken beat me to the reply :content:
  8. Notso9bit United Kingdom
    Norway
    Is it possible that it would work without that part? If not, maybe it is worth that I go back to the place I used it first, to find the piece :?
  9. Notso9bit United Kingdom
    Norway
    You were totally right. I made a makeshift plate out of a can top and it works now. Thank you.
  10. Staffan Rönn
    Stockholm, Sweden
    The function of the burner plate is critical. Without it you will continue to "shoot for the stars". I know of users that have made plates from scrap metal in emergency situations. Also people who have used the handle end of the multitool (that comes with the stove) as a burner plate.
  11. Notso9bit United Kingdom
    Norway
    Ah yes I made one out o the top of a steel can. I sent it but the image is waiting admin approval haha
  12. Christer Carlsson
    That's because you didn't upload a picture. You are using a third party image hosting (Imgur).
    Please upload pictures directly to the site in the future, and you won't get stuck in a moderation queue.
  13. snwcmpr
    snwcmpr Subscriber
    The Nova spare parts kit contains a flame plate.
