Optimus Trapper 81 box
Discussion in 'Optimus No:81' started by brassnipplekey, Mar 22, 2009.
  1. brassnipplekey
    Optimus Trapper 81 .. This version being without the small chained fill level plug on the side .
    1237724146-PICT3460.JPG 1237724156-PICT3461.JPG 1237724166-PICT3462.JPG 1237724176-PICT3463.JPG 1237724197-PICT3464.JPG 1237724208-PICT3465.JPG 1237724221-PICT3466.JPG 1237724239-PICT3467.JPG 1237724249-PICT3468.JPG 1237724261-PICT3469.JPG 1237724271-PICT3471.JPG
  2. johank
    Trapper did never have a side filling, just like Trangia and Optimus spiritburners it fills from the top.
  3. pysen78
    pysen78 Subscriber
    What he means is the "overfill protection" that was added to later models.
    Basically a threaded pop-rivet with a threaded plug in it. You take it out when filling, and any surplus fuel comes out through the side. Sorry for the less than perfect picture.
  4. julzgeraghty
    Hi,
    I've just found one of these at the back of a cupboard in our scout hut. Unfortunately the burner tube is completely empty with no sign of any mesh, material or any of the plastic bits. Any idea if it can be repaired? Oh and to make life interesting I'm in the UK.
    Thanks
    Julz
  5. theyellowdog
    Hi, This may help you see how it works, the fuel tube should be empty. You need the red tube part to fill the stove. Inside the stove is a fibre glass like insulation. You can feel it if you put you finger down the hole. The other plastic part is a measuring cup, you do not want to overfill this stove.
    A&H pack stoves in the US may have what you need.
    Optimus trapper filling pics
    Dan
  6. julzgeraghty
    Hi Dan,
    Thanks for the reply. When I said the tube was empty, I meant empty. All the way down to the adjuster plate (see pic below, the adjuster is 1/2 open). the fibre has long gone which is why I wondered if it could be repaired. The site you mentioned doesn't have the parts listed unfortunately.
    Julz
  7. theyellowdog
    That tube is meant to be empty. The fibre is in the inner walls around that pipe.
    When you fill the stove the safefill tube basically blocks the hole at the bottom of the tube to allow meths to flow into that fibre.
    A&H pack stoves had the parts you wanted on ebay for a long time so it can't hurt to email them.
    Dan
  8. julzgeraghty
    Right, I see how it works now.
    Thanks
    Julz
  9. lanevitt
    lanevitt Subscriber
