Parasene two pint stove.
Discussion in 'Fettling Forum' started by Bigbear, Jul 31, 2020 at 4:40 PM.
  1. Bigbear
    Bigbear United Kingdom Subscriber
    Bradford UK
    AD197A33-8726-4029-8882-8BC0DC732C67.jpeg Obtained this and it seems to be in pretty good condition as very few dings or bumps. Am I right in thinking that its missing a burner or flame ring, not sure how I tell which, or can one fit either ? Would Primus or Optimus stove supports fit do you think ?
    Will post more pics as I go.
    Thanks for any help.
  2. kerophile
    Hi @Bigbear your stove has part of a silent burner. It is missing inner and outer burner caps:
    Parasene, 2-pint, silent burner, collapsible stove.
    Stove legs from another 2 pint capacity stove are likely to fit, or you can make a set from steel rod.
    Leg dimensions and method of making stove legs:
    If you scroll down this link you will see the profile /dimensions for the legs of a collapsible 1.75 pint stove, A Radius No.17.
    Radius No:17 *
    If you check the burner top to the top of the flat section of the legs for your stove, it should be approximately 1/4 inch or 6 mm
    The drawing should be useful for any stove of this type.
    As to making the legs, have a look at this classic post by Bryan Miller:
    Making Replacement Legs
  3. Bigbear
    Bradford UK
    Much obliged, once more humbled by the knowledge and help on this forum, the internet has its downside but places like this would not exist without it.
