Perfektus No: 10
Discussion in 'Stove Forum' started by Tom Pedersen, Jul 2, 2020.
  1. Tom Pedersen
    Tom Pedersen Denmark Subscriber
    Denmark
    Hey.
    Have got this Perfektus No: 10 and are missing a new jet for it.
    Can i use a jet for Perfektus No: 10 from a Primus no: 00.
    If not, then where can I buy one.
    Yours sincerely, and thanks for your help.
    Tom.
  2. Harder D. Soerensen
    Denmark
    Try - if the thread fits - light it up and see how it runs?
  3. Wim
    Wim Subscriber
    I agree with Harder, this looks like another member of the 1-pinters family so will probably use the same jet as any other 1-pinter (and also the 2-pinters like N°1 and N°5 stoves etc.)
  4. Tom Pedersen
    Denmark
    Thanks for the response Harder
    A cleaning needle must be broken in the jet. I can only get the cleaning needle a little way down the jet. Have tried to change pump leather and RNV, and mounted another Perfektus burner, which has a hole in the jet.
    It has also been tested in a bucket of water and is not leaking, so it must be the pump it is wrong with, even though the pump leather is changed. I have tried the pump from my Optimus 00 and then there is life I have to try to work on with the pump.
    Tom
  5. Harder D. Soerensen
    Denmark
    Otherwise - come by Vinderup with two cold beers, and I'll have a look at it :-)
  6. Tom Pedersen
    Denmark
    Hey.
    Sounds good Harder.
    Tom
  7. Tom Pedersen
    Denmark
    The jet changed and now there is life in it.
    Thanks for the help.
    Tom
