Picked up my first camping stove: Coleman 426B
Discussion in 'Fettling Forum' started by zorobabel, May 8, 2021.
  1. zorobabel
    Picked up my first camping stove, a Coleman 426B - for very little money.
    Unfortunately the pump does not seem to work.
    Also found some loose bits in the tank.
    From my short reading, these seem to have been made in the 50's. The plunger cup seems newer being plastic. Is there a part missing here?
  2. hikerduane
    That looks like a newer style that maybe was pulled from a lantern or other stove. Maybe the original cup wasn't working and a PO swapped out parts. Wonder if the clip kept coming off this one and some goop was applied in a failure?
    Mine has threads on the shaft end with a square nut screwed on the retain the cup assbl.
  3. hikerduane
    You need this type.
  4. ROBBO55
    I have replaced the plastic bucket with a leather one. If you carefully remove the retaining clip it can be put back.
  5. zorobabel
    Thank you Hikerduane and Robb055!
    It seems hard to have to make a leather cup… will start searching.
  6. ROBBO55
  7. zorobabel
    So while waiting for the leather pump cup to arrive, I decided to start messing with the tank, rinsed a bit of rust out, tested the check valve by blowing in the pump cylinder...
    You guys are going to laugh really hard: It dawned on me (finally) that the little orifice in the plunger has to be covered with let's say ... a thumb :))
    A photo is worth a thousand words...
  8. Duck
    Duck United States Subscriber
    Just east of LaLa land
    The 426 is a beast. I keep a 200a lantern, a steel stove stand and a custom set of chef trays in mine. Weighs a ton. My favorite suit case stove. With the bronze tank yours was made 1954-57 if the tank was red it would be 58-61
  9. hikerduane
    The 426 family is heavy, but pick up a 418 if you want HEAVY.
  10. Duck
    I’m sure it’s a heavyweight but there is only one suitcase stove that really interests me right now. Just have to find a way to talk Doc Mark into selling it to me.
  11. ArchMc
    ArchMc SotM Winner Subscriber
    Mojave Desert, California
    In the sense of laughing with you. I’m sure we’ve all either done the same thing, or something equally boneheaded.
    ....Arch
