Pigeon Ignus and BD minicap?
Discussion in 'Stove Forum' started by Robert Radcliffe, Oct 19, 2020.
  1. Robert Radcliffe
    Stockport UK
    My Pigeon Ignus came without a genuine burner plate or silent burner so I wondered about pairing it with a Berne Dawg minicap (no legs version). My minicap has the legs and although the size is good, the legs cause a small gap between the cap and the burner bell, so a no go.
    Any thoughts or has anyone tried a different burner arrangement?
    Pigeon Ignus
  2. Doc Mark
    Doc Mark Subscriber
    Robert,
    I can dig out one of my Pigeon Ignus stoves, and see how an original, hand-made BD cap fits on it, if that would be of help to you.
  3. Robert Radcliffe
    Stockport UK
    @Doc Mark if you wouldn't mind that would be very helpful, assuming the new 3D printed ones are made to the same dimensions (I assume they would be).
  4. Doc Mark
    Doc Mark Subscriber
    Hey, Robert, (@Robert Radcliffe )
    Here are some photos that should tell the tale. I tried to use several exposures, because the photos were either too light, or too dark.
    Note the difference in the holes on each cap. Interesting, no?
    Note that the OEM silent cap, has a tube made into it, which works well in the recessed location of the burner. Gary's cap has that, too, but it is quite a but shorter than the original cap tube.
    This stove is my "parts Ignus", as it's not complete. I was happy to get it, nonetheless, as parts are hard to find. Note that the area into which the silent cap fits, is recessed.
    The OEM silent cap slides down into that recess.
    Hard to see, but the handmade BD cap is a bit too large to fit into the recess.
    Here, you can see that extra bit on the BD cap.
    Maybe this shows it better.
    The measurements should tell the tale, of the photos do not.
    The BD cap is a bit too large, though the stove "might" work with it balancing on top of the recessed area. You might want to look the measurements of the PuppyDawg cap, which fits one of my Baby Enders stoves. I can't get my hands on it, right now. But, if I can do so in the next day, or so, I'll check that for you. The BD/PD cap is only made as a cast offering, as Gary no longer makes his caps by hand. I hope this helps a bit. Talk soon, and God Bless!
  5. z1ulike
    Go straight to the source. E-mail Gary at bd@berniedawg.com and ask which cap (if any) will work best on your stove.
  6. Robert Radcliffe
    Stockport UK
    @Doc Mark thanks for that, I think my minicap has smaller dimensions I'll measure tomorrow. The legs certainly went into the recess but it still stood too far up.
    @z1ulike yes good idea Ben.
  7. Robert Radcliffe
    Stockport UK
    @z1ulike a very fast response from Gary and he's of the opinion the minicap would be best, he's even offered to do a test run as he has two of the stoves.
  8. Robert Radcliffe
    Stockport UK
    The end result of an exchange of emails with Gary. The minicap is underpowered but works with the PI. I've ordered one.
  9. Doc Mark
    Doc Mark Subscriber
    Hi, Robert (@Robert Radcliffe),
    Outstanding news! I'm glad that Gary came through for you, and that you have now set in motion getting one of his excellent Mimi caps. Please let us know how that works for you, when you have received and tested the cap with your Ignus! Well done, on Gary's part, too. Take care, and God Bless!
  10. Robert Radcliffe
    Stockport UK
    Hi Doc @Doc Mark yes I'll be happy to post the results and thanks also to you for your help in reaching this conclusion.
    Regards
    Rob.
  11. z1ulike
    @Robert Radcliffe I knew Gary would help you out and judging by that video your Ingus will be running like a champ once your new cap arrives. Congratulations on a great acquisition.
  12. Robert Radcliffe
    Stockport UK
    Finally I've got around to taking pictures of the BernieDawg Minicap on my Ignus. Basically it is completely transformed into a far more usable stove. A great result.
  13. Robert Radcliffe
    Stockport UK
    If you're on Instagram I've posted video of the Ignus with the Minicap installed. I'm not sure if links work, if not I'm rar_knives_and_leatherwork on IG.
    Login • Instagram
  14. z1ulike
    That thing is really running well. I might have to acquire a Pigeon Ingus myself. Good video too.
  15. Robert Radcliffe
    Stockport UK
    @z1ulike yes better than I'd actually hoped for. The video is after it had warmed up a bit and it was running at full tilt.
  16. Doc Mark
    Doc Mark Subscriber
    Morning, Robert (@Robert Radcliffe),
    Excellent results! So, the cap you ordered was from Shapeways? And, it was the regular Mini Cap? Looks like it's running very well, indeed!! I'm very glad you are now setup to use and enjoy your Pigeon Ignus!! Very clever little stoves, aren't they!?!! Thanks for sharing your photos of your new Ignus.BD cap combo in action. Running a treat! Take care, and God Bless!
  17. Robert Radcliffe
    Stockport UK
    Hi Doc @Doc Mark being in the UK we order from i.materialise.com rather than shapeways. Yes I'm really pleased with the outcome, I imagine the Minicap may be as good or better than the original silent burner.
  18. Doc Mark
    Doc Mark Subscriber
    Howdy, Robert, (@Robert Radcliffe),
    Which Mini cap did you get? Legs, or no legs?
  19. Robert Radcliffe
    Stockport UK
    Definitely 'no legs' Doc, I tried my 'with legs' version and it stands proud of the seating leaving an air gap.
  20. Doc Mark
    Doc Mark Subscriber
    Hey, Robert,
    Many thanks! I've got a couple of the original, hand-made Mini caps, but would like to try the cast version, just for fun! Thanks, again, and God Bless!
