PRESTUS?
Discussion in 'Mystery Stoves' started by Wim, Jan 9, 2013.
  1. Wim
    Wim Subscriber
    Hi All, just after new year, my last stove-purchase of 2012 arrived at my humble castle. I think it is a French stove, but am not sure so I post it in the mysterious section. If anyone out there can tell me more about it, be my guest!
    The thing is biiiiiiig when compared to other twin-burner ranges. Construction is stamped sheet, not cast but pretty thick sheet was used. As you can see, the fount is also laaaaarge! Both burners (I'm quite sure this is a petrol/white gas thing) have their own vapo/generator so no master & slave intercourse here! The castings are aluminium. Both knobs are missing, and I'm rather puzzled as to what is the function of the central tap. Everything is rock-solid seized up so a lot of creeeeeeping oil will be needed I guess. Also the filler plug/air pump nozzle is gone on permanent leave. Enough blabla, enjoy the photo's! (For obvious reasons, no flameshots as of yet.....)
    1357759381-PC040042_opt.jpg 1357759406-PC040043_opt.jpg 1357759428-PC040044_opt.jpg 1357759447-PC040045_opt.jpg 1357759471-PC040046_opt.jpg 1357759496-PC040047_opt.jpg
    Best regards,
    Wim
  2. threedots New Zealand
    Hello Wim.
    What a nice looking stove you have there. :mrgreen:
    At a guess, :-k I think that the valve in the center would shut off fuel to one burner or the other if it was not in use. Probally a safety feature in case of a leak.
    Where it is positioned in your photo, I looks like it is set to supply both burners.
  3. Rick b
    Boise
    Another beauty Wim, you are on a roll.
  4. Wim
    Wim Subscriber
    A further indication as to it's probable french origin are the "brevets" numbers found on the fount's attaching strips; these are 689954, 38422, 706364, 692402 and 294395.
    Best regards,
    Wim
  5. Lampenkueche
    Hello Wim & All,
    An Prestus arrived here, but its a little bit different to Yours. Interessting System with 1/4 Gear for full open. Filler Cap is lost and have Anybody an Idea for what the Cap on the left Side is?
    Cheers Peter
    1390667644-Prestus_01_kl.jpg 1390667673-Prestus_02_kl.jpg 1390667692-Prestus_03_kl.jpg 1390667709-Prestus_04_kl.jpg 1390667725-Prestus_05_kl.jpg
  6. Wim
    Wim Subscriber
    Hi Peter,
    size wise both look to be the same, but the burners are clearly different! I think both run (or, should I say 'ran'? :-k ;) ) on white gas/gasoline/Coleman fuel. Have you found any further info on the stove as to where it was made? It puzzles me no one seems to have heard of the marque. So far I have not done anything to mine, it just sits there waiting... :oops: .
    Best regards,
    Wim
    PS., just tried to google once more for more info, the only link that connected "PRESTUS" or "PRESTUS FRANCE" with stoves was leading to.....this post! :roll:
  7. Longilily
    Longilily Subscriber
    Dungeness
    Giving this thread a bump, as I've relieved Wim of this lovely stove and would appreciate any pics of the missing parts , if anyone has any :D
    Guess at worst I could copy the above knobs :-k
  8. Matthew92
    Matthew92 SotM Winner Subscriber
    I thought you'd have that going by now Ray. ;)
  9. Longilily
    Dungeness
    Bah I wish ](*,) I have the premises, tooling, machinery etc its time I'm extremely short of :doh:
    ( hope your getting on ok with the mill [-o< )
  10. Matthew92
    You'll get there mate. :thumbup:
    The mills in place, motor runs, I just need a belt. Will check to see what we have in stock at work. [-o< :lol:
  11. Longilily
    Dungeness
    image.jpg Made a start today, but not long into the strip down , I found a couple of cracks which will probably mean, blasting off the chrome to prepare the area for re soldering ](*,):doh:I'd of loved to of kept the chrome, oh well :-({|=
    Fingers crossed aye :roll:
  12. Longilily
    Dungeness
    @Lampenkueche @Wim
    Yes Peter, it appears to be an NRV, that you attach a pump to
  13. Michel
    Michel Subscriber
    France
    Prestus is french, a brand of Ekinox
    EKINOX, 70 bis, avenue Jean-Jaurès, Gargan-Livry (S.-et-O.).
