Preway 4521A
Discussion in 'Prentiss Wabers (Preway)' started by BradB, Jul 10, 2018.
  1. BradB
    Central North Carolina USA
    After restoring my Prentiss Wabers No 8, I had my eye open for something similar. I found a Preway, same company, in the 4521A model. It looks like it has seen light use. It required very little from me. I washed it a bit and pressure tested it. No leaks showed up but the NRV in the pump allowed the pump shaft to stand proud. On this model there is a pip that is accessed from the outside of the removable pump. The spring seemed very weak so when I dug out an Optimus pip I tried another spring. The pip fit perfectly but the spring was too strong. So I slightly stretched the original spring and it seemed to solve the issue. I really like this little double burner. It seems to be from the 1940's according to more knowledgeable people.
  2. Metropolitantrout
    Santa Cruz, CA
    Burns bright, well done! Jerry
  3. ArchMc
    ArchMc Subscriber
    Mojave Desert, California
    I like the burners on these, and find it easy and intuitive to achieve a simmer with the lever-action valve on the right hand burner.
    ....Arch
  4. coyotte joe
    lansing michigan
    I just picked one up last weekend same model p4521. were you able to find any dates on yours?
  5. ArchMc
    ArchMc Subscriber
    No.
    ....Arch
  6. BradB
    I think the 45 in the model number means 1945. Brad
  7. wtspe United States
    NE Ohio
    That's about right. The 1945 models were made for a few years until the 4821's, 4822's and 4823's came out in 1948.
    I don't know what the suffix letters (P and A) stood for. Slight differences in the pumps and filler caps, I'm thinking, as there are several variations of these. I just wish Prentiss-Wabers would have used actual check valves instead of NRV's. I really like the flame pattern through those steel burner plates.
