Prim Compact gasoline stove
Discussion in 'Russia' started by presscall, Feb 15, 2020.
    Inspired by @gieorgijewski featuring his Prim Compact in the Stove Reference gallery I dug mine out of deep storage to have another play with it, having relegated it there in frustration with it’s quirks. Crucially, for someone who likes to cook with a stove and not just boil water, it’s a stove that’s either on ‘max’ or ‘off’ with no simmer setting.
    Having had another delve into it it still won’t simmer, but although I concede that I’ve robbed it of its distinctive ‘of the era’ yellow and blue paint scheme I couldn’t resist giving it a more subdued paint finish. I acquired the stove cheaply, the pot rest missing, so I made one out of 5mm rod with silbrazed joints. Though I’ve used stove paint, it will soon burn off the trivet - I’ll report back with post-firing photos subsequently.
    Here’s how it looked before.
    First I looked into “why no simmer?”
    At best, this is possible for a short time until it flips into underburn or, if throttled down too much, extinguishes.
    The burner disassembled. The regulator spindle is the one inline with the fuel inlet pipe. The spindle mounted vertically in the burner is a jet pricker device, accessible to operate with the regulator control knob and shaft through a hole in the stove box when the burner/fuel tank assembly is installed in use. Not practical at all.
    I think this contributes significantly to the lack of a simmer setting, a straight-through, unrestricted passage of fuel through the valve. Usually, a regulator spindle is at right-angles (or nearly so, thinking Svea 123) to the passage of fuel, with the venturi/baffle effect of fine passages contributing to the control of fuel.
    So, I tried inserting a length of wire, close-fitting in the fuel pipe bore.
    Disappointing. No real improvement.
    I tried not pressurising the fuel tank very much. No improvement, and too low, the burner underburned again.
    Surprisingly, given the short stroke, O-ring pump washer and narrow bore of the pump tube, the pump is quite efficient.
    Pump and non-return valve.
    The NRV-to-pump tube end cap seal was rubber, which I replaced with a lead seal before re-installing it.
    While I remember, for anyone dismantling one of these, removing the pricker spindle - with the jet removed - is done by screwing it clockwise into the burner riser until it emerges out of the top.
    This photo shows how the jet pricker unscrews from the tip of the spindle. No wrench flats, the pricker has to be gripped in plier jaws.
    The spares kit. I’ve introduced an Optimus 111 jet in there ...
    ... part of my ‘simmer’ trials. The 111 threads match and the Prim pricker passes through the jet. Same jet orifice size, predictably no difference to the fuelling behaviour.
    Burner caps.
    Those three notches in the lower circumference of each cap engage with corresponding projections formed in the burner bell. The outer cap can then be twisted anti-clockwise on its ‘ramped’ lower edge flare to secure both caps firmly in place.
    A refinement worth doing is to smooth off the sharp corners of the tank stowage clip in the stove box.
    836B6BA6-EE51-48CA-B5D0-894031DE6C33.jpeg 1E70E2E0-FC17-4932-A5BE-66A9695B8A58.jpeg
    Finally, firing. Ok, no simmer, but the output as a water boiler is impressive.
    I’ll post photos shortly of what that fiery blast inflicted on the trivet paint.
  2. The Warrior
    In the 'Nois man.
    The new paint job is a huge improvement, imo. Cool looking stove, hope you get it figured out.
  3. presscall
    @The Warrior
    Thanks! I’ve run out of ideas for getting it to simmer for now.
    Still, the paint job on the trivet has mostly held up and I won’t be relegating the stove to ‘deep storage’ any time soon.
    Thanks again to @gieorgijewski for giving me the incentive to look afresh at the Prim Compact.
  4. The Warrior
    In the 'Nois man.
    Sorry I'm no help, haha. New to all of this, I just don't understand the mechanicals yet.
    The green paint gives it that military look, which I'm a fan of.
    Also, I'm surprised the factory that made them didn't round the corners of the clip like you did.
  5. SveaSizzler
    Tucson, Arizona
    Stamp a Crow's Foot on it, and tell the gullible it's a Military No. 9-3/4.
  6. presscall
    I’ve been more inclined just to stamp on it for most of the time I’ve owned it.
  7. SveaSizzler
    Tucson, Arizona
    I meant the Broad Arrow.
  8. presscall
    @SveaSizzler
    Yeah, I know, my sense of humour.
    You meant one of these.
    Should be the USSR equivalent really.
  9. SveaSizzler
    Tucson, Arizona
    That's it. The Rune of Tyr, Saxon War God.
    Used to designate Crown Property since before the Danes.
    And, yes. I knew you were kidding.
    I guess the Russian equivalent would be a Red Star and/or CCCP for USSR. Not expert on Soviet markings.
    ''Military No. 9 -3/4'' was a JK Rowling reference.
    Nicely fettled, by the way.
  10. presscall
    Parts stowed.
  11. hikerduane
    Thanks John, will steer away from these if I see one.
  12. presscall
    @SveaSizzler
    A red star would have been a bit much, but the name ‘Prim’ in Russian script and a number 1 - signifying a 1st-rate stove or marks out of ten depending on your point of view - seems to work. The rectangular frame around the ‘1’ evidently signifies a unit number marked on military vehicles and white lettering and numbers is, or was, too.
    Location on the fuel tank was chosen where it was less likely to scratch off stowing the tank in the box.
  13. Twoberth
    England
    Very funny:D/
  14. gieorgijewski
    gieorgijewski Subscriber
    FUEL consumption test
    1 hour
    max power
    results
    maximal consumption as 100%
    btw/ John look on thats PT2 works
  15. gieorgijewski
    5:30
    simmer ?
  16. presscall
    @gieorgijewski
    I see it simmer Gieorgi but not knowing Russian, when Alex is pointing to the fuel pipe on the Prim I don’t know what he’s saying.
    Do you know what he did to get the Prim Compact to simmer?
    Interesting fuel consumption comparisons. Ogonek has a silent burner installed I see. Makes fuel consumption better? Worse? Same? I like the Ogonek, my favourite Russian stove. A Prim Compact that simmers might challenge it!
  17. salan3
    salan3 United Kingdom Subscriber
    Cheshire UK
    I watched this vid on YT and put on captions with auto translate to English. Not perfect but helps a lot.
    Alan
  18. gieorgijewski
    ok ill check it again
    but - after a few video:
    "hole is big as the barn" - range of real simmer is very short
    half by half examples is "puffing"
    my -with bigger amplitude
    only 3 was with orange flame
    mostly wide "sunflower shape" blue
    1 example - out of commentary ...
  19. presscall
  20. presscall
    I have an idea for a way of restricting the flow of fuel better than that length of wire I tried in the fuel pipe.
    I’ll report on how it goes.
