Primus 210
Discussion in 'Primus No:210' started by Chopperbob, Apr 3, 2019.
  1. Chopperbob Czech Republic
    Czech Republic
    Hi all,
    Last week, I found the attached Primus 210 in the basement of an old house we are currently renovating.
    Since am not an expert, I found your website to learn a bit more about the history of this stove and interesting to read so much useful information.
    Attached are some pictures as I found it and with the N2 stamped it appears to be a 1924 model.
    IMG_4837.jpg IMG_4830.jpg IMG_4826.jpg IMG_4823.jpg IMG_4829.jpg IMG_4831.jpg IMG_4833.jpg IMG_4836.jpg
  2. kerophile
    Hi, Welcome to CCS.
    A nice find of an interesting stove. The burner is a later replacement as it looks to be a Perfectus rather than the expected Primus brand. Perfectus manufactured in Czechoslovakia so would perhaps been more easily obtained.
    Here are some photos of a sister stove, made in the same year of 1924:
    1924 PRIMUS 210 OUTFIT.
  3. Harder D. Soerensen
    Denmark
    Welcome @Chopperbob
    The 210 is a great classic. Hopefully you can get it running - you might be amazed how powerfull it actually is.
    The loose flame-ring around the burnerhead can easily be put back in shape by placing it down on a regular car trailer hook and then carefully hammering it back to a nice shape with a rubber/wooden mallet (hammer).
  4. JP2
    JP2 Subscriber
    Canada
    Hi and Welcome
    A clean tank of fuel is important as the NRV (non return valve) also.
    Here a link to give you an idea.
    Non-return valves
  5. Chopperbob Czech Republic
    Czech Republic
    Thank you guys for the feedback. Very much appreciated. Will try to get it running. Do you think the box is original or from a later model? Thanks!
  6. JP2
    JP2 Subscriber
    Canada
    Original and if you could post more pictures of the lock mechanism that could help me to reshape the one on my 1933 Optimus 210.
    Thank
  7. Simes
    Simes Subscriber
    @Chopperbob. A wonderful find, which I'm certain probably has many stories to tell between now and then.
    It may not have an original tin, nor it's burner, but it has served it's purpose over many years. And can continue to do so with a little tlc.
    If you are familiar with this type of stove then please don't take offence to the suggestion to have a good browse here before any fettling. All members have harrowing tales of early mistakes when attempting restoration.
    The stove itself should be straightforward, but care should be taken with the tin, I know to my cost that slow is better. It looks like you have a nice useable setup with some simple steps.
    Look forward to further reports.
  8. kerophile
    Hi @Simes, I think the tin is likely correct for a 1924 Primus No.210
  9. Chopperbob Czech Republic
    Czech Republic
    Hereby attach additional pics of the lock mechanism. Might keep the stove in it's original condition. Since I collect and restore vintage motorcycles, with bikes it's sometimes better to keep the 'patina' rather then over-restoring.
  10. JP2
    JP2 Subscriber
    Canada
  11. JP2
    JP2 Subscriber
    Canada
    Interesting enough, the inside finition of my 1933 is a little different compare to the 1924
  12. Simes
    Simes Subscriber
    @kerophile, I was more.worried about posssible tin damage really after all.your conservation efforts.
    It was.probably going to be the original, bit many pop up with odd combinations.
