Primus 230 fettle
Discussion in 'Fettling Forum' started by nmp, Jun 24, 2019.
  1. nmp
    Bought this old stove recently and have started a renovation on it.
    First job was to try and pull the dent out where the riser had been pushed into the tank as can be seen in the above photo.
    I decided to try and fill it with water and freeze it and push the dent out from inside so to speak.
    New washers on filler cap and reserve lid to seal it then into the freezer for 8 hours checking on progress every now and then.
    I obviously did not get all of the air in the tank replaced with water as there was a hiss of escaping air as I removed the filler cap. So full pressure was not brought to bear on the dent by expanding ice. But some of the depression was pushed out as can be seen in the second photo, below.
    I could try again but have decided I can live with it rather than risking blowing the tank up!
  2. ROBBO55
    Good to see the freezing method does work. :thumbup:
  3. shagratork
    I also agree about the freezing method, but few people seem to be willing to give it a try.
  4. nmp
    Now have the toughest NRV ever to remove hopefully without removing the pump tube.
    I have soaked it in penetrating oil, frozen it, heated it applied brute force on the tank with the removal tool in a visa and still no joy at loosening it!
    I really want to do this without mangling the head on it!
    Now soaking in penetrating oil and meths!
  5. Twoberth
    England
    You might want to make one of these.
    Its not a substitute for soaking and patience, but it helps prevent mangling the head.
  6. nmp
    Decided to give up on the NRV FOR NOW @Twoberth But have bought the bits to make a removal tool similar to yours!
    I now have the tin in an electrolysis tank to strip the horrible blue paint job!
  7. nmp
    @Twoberth the NRV finally submitted using a tool made to a similar design as yours but more simple and without sacrificing a pump cap.
    1. Cut a slot in the end of a coach bolt to suit the NRV head, onto which you have previously wound 3 nuts.
    2. Adjust 2nuts to fit flush with the end of the bolt and tighten them onto each other so they do not turn.
    3. Grind the bolts round so they are a good fit into the pump tube.
    4. Tighten the third bolt against the head of the bolt.
    5. Place on NRV head in tube and undo! Hopefully!
    The NRV was so tight that the slot still deformed while applying pressure despite having the bolts around it for support!
  8. nmp
    Tin after wr hours in electrolysis tank and a scrub up.
    I have yet to wax it up to stop rust.
    Several other problems were overcome! Once the NRV was refitted it leaked a new spring cleaning the mating face no joy suddenly realised the pip had been cut at an angle. Another new pip cured it.
    Leaky jet was fixed with a tweak and away she went.
    Last photo shows a selection of tools used and the stove in action!
    110ryears old and brewing again.
  9. Twoberth
    England
    @nmp
    Excellent work, Thanks for posting.
  10. ROBBO55
    Congratulations @nmp , it's cleaned up nicely. :clap:
  11. igh371
    Durham
    @nmp Never used electrolysis myself but that is one stunning result refurbing the tin:thumbup:
  12. nmp
    @igh371
    I use this method a lot on the tins of pocket outfits with great success it cleans them up and with a coat of Briwax they seem to last without rusting again.
    In this case the coat of horrible blue paint has at least protected the surface apart from the lid which is a bit pitted.
    They still retain their character which is a bonus!
    Cheers Nick
  13. Radler
    @nmp
    There is no need to sacrifice a pump-lid to make a good non-slip NRV-tool. A common chrome-vanadium-steel 5.5mm Allan-key can transfer much more torque than needed, just through the 6mm hole of a pump-lid.
    Making a special key for NRV removal
    Radler
  14. Tony Press
    Good job, @nmp.
    I like those old Compact Primus Outfit
    tins.
  15. nmp
    @Radler excellent thread on your NRV tool.
    I will be looking into making my own.
    Enclosing the head of the NRV seems to be the way stop slippage then backed up by the pump cap keeping it under pressure.
    Removing NRVs is one thing I always dread as they rarely seem to come out easily.
    Removing the pump tube can present problems in itself mainly with getting a neat soldered joint back into the tank!
  16. Spiritburner
    Outstanding result. I have a couple of sizes of electolysis bath - one for big projects & one for very small. Very effective. A stubborn nrv tool is on my do list.
  17. shagratork
    Excellent! :thumbup:
  18. Spiritburner
    Just for me toolbox!
  19. nmp
    @Spiritburner Ha ha not thinking of producing them for sale then hahaha!
    :lol::lol::lol:
