Primus 303 - 1914
Discussion in 'Primus No:303' started by z1ulike, May 12, 2020.
  1. z1ulike
    This stove is missing some parts and originally came with a roarer burner I believe.
    The "D" on the bottom indicates it was made in 1914.
    This is from the 1914 Primus catalogue showing what the stove originally looked like.
    The cast iron trivit seems to be original to the stove as shown here in the 1914 catalogue.
    I'm not familiar with this burner but I suspect it's this one shown in the 1914 catalogue.
    It's obviously missing some pieces.
  2. Tony Press
    Can you photograph the burner cap and top of the burner in detail, please?
    Thanks in advance.
    @z1ulike
  3. Lennart F Sweden
    Vänersborg, Sweden
    That burner looks quite similar to the one used on early 1950's Primus 16.
  4. Rangie
    Rangie Subscriber
    Excellent stove, well presented :thumbup:
    It is likely to be a 4155 or 4190 burner. Does it have a cleaning needle and is it present when the valve is opened or closed?
    Alec.
  5. Lennart F Sweden
    Vänersborg, Sweden
    The picture looks like there should be a needle in upper position when valve is closed.
  6. z1ulike
    Since you asked so nicely, here you go...
  7. z1ulike
    @Lennart F @Rangie Yes, a cleaning needle protruded from the jet when I turned the spindle all the way to the right with a pair of needle nosed pliers.
  8. Rangie
    Rangie Subscriber
    Nice one, a 4155 burner :thumbup:
    Alec.
  9. z1ulike
    Thanks @Rangie it's not the first bad guess I've ever made. Thanks for sorting things out. Shame it doesn't have the original roarer but it is what it is.
  10. Lennart F Sweden
    Vänersborg, Sweden
    A much later silent burner is the most common found on circa 1910-1940 standard roarer stoves in Sweden - I assume that is common practice in many countries.
