Primus 5 roarer power
Discussion in 'Stove Forum' started by Paraffinhead, May 24, 2020.
  1. Paraffinhead
    Paraffinhead United Kingdom Subscriber
    I'm thinking of taking my home brewing up a notch and going back to all-grain, for which I need to boil 23 litres or more of wort. My best candidate for heat output would be my Primus No.5 roarer. I've read some discussion on here and a few tables of heat output in kw but not sure where the 5 would fit. Would it be closer to the 2.7kw end or higher?
  2. kerophile
  3. presscall
    @Paraffinhead
    You could go a notch higher on output with a Primus No.4140 silent burner, as fitted to a Primus No.10.
    A No.10 with the 4140 burner attached (can’t see if it has the caps or not though) is currently up for auction on ebay UK.
  4. Paraffinhead
    Thanks both - looks like I'd need to partner the 5 & my Radius 5S then or fit another roarer to the Radius 5S for some serious horsepower :). There should be room under the large pot required for two two-pinters.
    Now, if I could find a complete 4-burner furnace...
